Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell 1699 I have taken apart the pro heat cleaner. I reassemble it. The top cover will not go all the way down. Any suggestions on getting back together. Thank you
    President:
  • 1,673 Answers
Make sure that the piston on the bottom of the smart mix valve is in the water only position.(needs be be on the knob and not sitting in the hole). With the top off, it is easier if you have a block of wood or something under the base to hold it up. Other wise it drops down and the screws can't grap the base. Also make sure all hoses aren't being pinched.
Posted on Aug 10, 2008
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
Need a manual for pro heat brissell model 1699
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
reyy536
Mar 05, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can't reassemble top of carpet cleaner
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Cleaner
If it is completely dead, then either a bad cord, switch, motor, or a broken connection, it will have to be taken apart to find the problem.
Aug 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699-1 reassmble
I FIGURED IT OUT!!!!YAY.
the piston comes out easily with a pair of plyers.hold the cover on your lap upside down, smart mix knob closest to you,there is a slot for the piston to fit in to, turn the knob slightly (about 1/2") you will see that you can lift the knob slightly out of the way then you can slide the piston into place. leave the knob at that position to hold the piston and slowly put the cover back in place. if the piston goes in,just before you put the cover all the way down turn the knob back to water only.if everything is in place, PUT THE SCREWS IN!!!! hope this helps.
Jul 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
BISSELPRO HEAT CARPET CLEANER
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Jul 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro Heat
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49925&thid=581652
Bissell Pro Heat
posted by saboulis on May 09, 2008
My bag that you put the water in rip around the top and I would like to replace it. Where can you get the part for it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You have a Bissell 1699 ProHeat Clear View Upright Steam Cleaner and the best thing that I can tell you is to contact some of the companies I will list below. I always check with your local vac cleaner dealer in you area as a suggestion. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
May 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
63 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
