Question about Uniflame FG2204C Grill
When we lite it, it only lites very low you can not cook any thing on it, then one time we lite the flames stayed up
    Brigadier General:
  • 4,736 Answers
Turn the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY (Slow Motion, slow). Once the tank valve is fully open, light the burner and turn it to the highest setting. Do the flames appear to be correct for the highest setting? If so, you've solved the problem. Just remember to always turn the tank ON VERY, VERY SLOWLY.
If that didn't solve your problem, the grills regulator is permanently locked up. You will need to replace the hose/regulator assembly. You can purchase one at any hardware or home center store that sells gas grills. Take the old one with you for comparison purposes.
Hope that solved your problem and Happy Grilling!!
Posted on Mar 20, 2011
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Oct 15, 2013 | Coleman 5040-751 BackHome Open Flame Patio...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Polite will stay lite but when you turn it on it will only stay on for a 10 ti 15 minutes and shuts off
Check to see if the pilot flame is hit the themcouple bulb. there is a angle sheild that mount be hind the pilot lite to keep main flame from pulling the Flame up and way from pilot lite and the bulb. If can't find one E-mail me And I will sent you one. Ken's Repair
Jan 18, 2011 | Vanguard International Blue Flame - Large...
Low heat
clean burner holes with wire brush real good... if one burner lites and the next lites,but the first burners flame drops-replace Regulator. Its the hose that connects your tank. tapping metal housing with plyiers the next time it does it will show the plastic wheel inside housing is stuck and cannot allow the gas to flow
Dec 31, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
The oilot lite keep going out
Check to see if the pilot lite is going past the pin- (flame sensor) if not then your flame is too low , Clean the pilot oriffice or use air and blow out the system for dust.
Dec 08, 2009 | Desa International Heating & Cooling
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Jan 16, 2009 | Heating & Cooling
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Dec 08, 2008 | Honeywell Electronic Programmable...
Uniflame FG2204C Grill Logo
151 people viewed this question
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
limabeenie
Level 1 Expert
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
