Question about Dewalt DPD3100 Gas Pressure Washer
I have a Dewalt DPD3100, 2 yrs old, never had any problem, water supply hose is attached, water is going in but no water out?
    Sergeant:
  • 259 Answers
Take the hose off the gun and see if water comes out. If so the gun has to be taken apart and cleaned. Also where the water hose goes in to the machine there is a screen filter which you might have to clean if water is not comming out on the gun side. Use a screwdriver and pry it out carefully around the edges Clean the screen with a wire brush and put it back in and try it.
Posted on Mar 20, 2011
Air lock in water pump
Don't screw the hose so tightly, let it leak slightly, and lower the water pressure going in.
Jul 01, 2014 | Dewalt D24000S Wet Saw With Stand
My DeWALT 18v drill will only hold minimal charge. I took the drill and battery to my local home depot and was told that the batt checked fine it must be the charger but i wasnt totaly convinced. any...
I bought brand new replacement batteries from Grainger Supply.Charged the batteries and they would go dead without even using them.When you did use them they were good for only a few minutes.Called Grainger,they called DeWalt and found there was a recall on the Yellow topped batteries I had just bought.I don't know what series but they were the yellow topped 18volt batteries.Hope this helps?
Jan 14, 2010 | Drills
De Walt pressure cleaner not drawing chemicals
pull the hose off at the end going into the water pump there is a screen inside of that fitting remove it and clean reinstall and try it again, sometimes the pressure washer has to be on low pressure in order to pull soap out of the bottle.
Nov 22, 2009 | Washing Machines
Water goes in very slow. Cleaned the intake filter where the hoses connect.IS the valve worn out to where it does not open all the way?
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No water is going in
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
Washer has one hose how do i hookup to 2 spigots
Those machines only have 1 cold water inlet.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2009 | Kenmore Washing Machines
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Dewalt DPD3100 Gas Pressure Washer Logo
238 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Tim Venetis
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
