Question about Simo Classic Twin Carriage Stroller
I have a simo classic twin carriage with no seat straps. how can i purchase these straps? i cant seem to find a website.
Hi, my friend is giving me a Bobs Revolution Duallie stroller (2007) however her husband cut off the harness straps. Is there anywhere I can go to purchase a replacement seat with the harness?
I have a similar problem. The crotch straps on mine dry-rotted and tore off. I spoken with BOB reps and they say there is no seatbelt replacement. I\'d have to buy a whole new seat. Fortunately I still had the buckles and I was able to just sew replacement straps in place. Good luck!
Apr 19, 2011 | BOB Trailer Revolution Duallie - Navy Twin...
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
Folding with seats in
It cannot be folded with both seats on. If I remember correctly, you may be able to leave the rear seat on, but the front seat needs to be removed for sure. It is a pain for sure to remove and replace the seats each time you get in and out of the car. Sorry. Congrats on your twins thwough. =)
If you would like to confirm, please download the user manual from the Perego website.
Good Luck! from Moms Just Know
Sep 30, 2008 | Peg Perego Duette MT Newport Twin Stroller
Cant tighten straps
To answer this in detail, I need the car seat name and manufacturer. Always the best bet is to look in the original owner's manual. If you don't have this, it can be downloaded from the manufacturer's website.
Sep 29, 2008 | Evenflo Chase Comfort Touch
Straps nearly impossible to tighten!
If you grab the straps up at the top near the shoulder and pull hard you can get a bit of slack at the bottom, they are ridiculously difficult to pull, I have twins and both seats are the same, there should be a handle to pull at the bottom but it just takes strong fingers to do it without that.
Mar 24, 2008 | Cosco Alpha Omega Elite - Hammer Print
Bertini twin stroller
I have a used one for sale - where are you located
Jan 11, 2008 | Bertini Twin Steerable - Classic Check...
Maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Jan 08, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Broken hood on nordic cruiser
It appears that Simo have gone out of business, and their partner company Bertini is not supporting simo strollers, so I don't think you'll get much joy from them. Best I can think of is to take the stroller to any reasonable machine shop, and get them to make a replacement for the broken part from an appropriate material- it is probably the same or a mirror image of the one on the other side. This shouldn't cost too much, but ask first. A quick solution would be to fix an adlustable strap to the hood, going forwards and backwards from the front near the centre. This strap could then be attached to the handle and to the other end behind the hood. ( best way is a buckle stiched to the hood near the open edge, with one continuous strap running from a loop round the handle, through the buckle, then down to a piece of strong elastic attached to just below the base of the hood at the back. A bit of experimenting with the tension on the elastic should get this working quick enough). This may not be an ideal solution, but it may be easiest and cheapest. Hope this helps, if you need to find a machine shop near you then please give a general area and I can see if i can find you one :)
Jul 04, 2007 | Simo Nordic Cruiser 417 Stroller
Simo Classic Twin Carriage Stroller Logo
Top Simo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Simo Baby Gear Expert? Answer questions, earn points and help others
