Hi my candy eclypsa washing machin cj534. ihave heater element in rear side but icant dryer after washing please can you expline me how to oparate and make dryer thank you your customer
    Brigadier General:
  • 6,277 Answers
I think a manual would help you ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 20, 2011
My washing machine motor not rotating in washing cycle. Motor works well in Spinning cycles, but not working agitatewashing movement in any cycle. It's water filling, stopping and draining all works
Would help to have the model and type...but typically if the tub is not agitating the coupling between the motor and the tub is worn out or broken. However, if it is spinning properly, it probably indicates a problem with the transmission. Really need to know what type of washer it is to help pin down the problem. Any "burnt" smells coming from the washer? Give a little more information and maybe we can figure it out. Top load...side load, make and model preferred. You can locate that information on a plate usually attached inside the door on most models.
Apr 17, 2016 | Candy Washing Machines
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
Candy CE124 washing machine
tricity bendix washing machine will not complete cycle aw1201, its starts the cycle then goes straight to the end
Jun 29, 2008 | Washing Machines
Heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
CNW136 Dryer not working !!
lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Jan 08, 2008 | Candy CNW136 Front Load Washer/Dryer
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Heating element
you have to remove the back half of the case by removing the lid, screws at the sides (bottom) and from the bottom rear. then from the top centre. slide the rear case backwards by seperating the hose bracket and the element is at the bottom of the outer tub.
Jun 10, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Jan 18, 2007 | Candy CN126 Front Load Washer
Dryer not heating up
Hi Mally Try the following thread - http://www.fixya.com/problems-solutions/t103658,p117053/Bosch-Dryers.aspx It might also be relevant to your problem. Another pointer - - There might be a heat-sensitive fuse in the exhaust section of the dryer. The fuse is designed to turn off the heater element if the exhaust temperature gets too high. If this fuse is defective, it will keep the heater element from getting current. Good luck!
Jun 22, 2006 | Candy CNW156 Front Load Washer / Dryer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
