Question about Garden
I do not have the manual to this washer. I do not remember how to operate the "choke-throttle" to start the engine. Or, how can i download a copy of the owners manual?
    Sergeant:
    Champion:
  • 250 Answers
Put the lever on choke and put the throttle about half way and try to start it. Make sure the gas valve is on
Posted on Mar 20, 2011
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Kawasaki barako 175B ES repair manual
Here is a procedure I have foud that is very effective. Pull open the choke. Then, open the throttle and SLOWLY operate the kick start lever several times so as NOT to start the engine. Then close the throttle and slowly turn throttle grip until it just starts to open the throttle. Once it starts to engage the throttle, turn about 2 degrees, no more. Then kick start it. Might have to do two or three times.
Jan 31, 2013 | kawasaki Motorcycles
I have a 2005/2006 Husqvarna GTH 2654 Garden Tractor with a Briggs & Straton ELS 725 engine that I am having troubles with. I have had other problems with this engine but this is something different....
check the operators manual but I think that by allowing the engine to be at high rpms then dismounting from the unit , activated a seat safety microswitch that cuts the rpms back or is designed to shut down the engine
Talk with the manufacturer dealer about the problem
Mar 23, 2017 | Husqvarna Garden
Having a difficult time starting engine. I tried with the choke all the way out, and the throttle shut down, I tried with the throttle half way open, and the choke half way out, and I can't get the engine...
I have the same problem with my craftsman - I hold the trigger open on the wand as I pull the start cord. I also put some Sta-bil fuel stabilizer in the fuel to help it run. You may have broken an O-ring if you started your washer without water hooked up - it only takes a second to bully that o-ring. If so, either find your manual or call the dealer to see if they have another one so you can copy or at least look at the manual to know the how and where.
Hope this helps!
Nov 06, 2010 | Psi 2500 Mobile Pressure Washer 5hp Honda...
What would cause a pressure washer to cut off after you pull the handle to get the water started
We used power washers for years
When you pull the trigger, the engine is supposed to accelerate because the back-pressure on the pump is released.
The back-pressure is why you're supposed to keep the gun trigger open when starting the engine. It sounds like you're starting the engine with no water passing through the gun.
Inspect the exhaust port >> if exhaust is clogged with carbon or dirt, then the engine will not run at high speed.
The problem may also be cause by a rusted choke lever. If you notice when a small engine accelerates, the choke lever moves up as the carburetor demands more gas.
Start the engine with water passing through the gun >>> move the choke lever a little bit at a time and see what happens. Keep water going out of the gun. When the surfaces are cool, spray WD-40 on the lever and see if you can free it up. WD-40 is extremely flammable.
If your engine will not fire at all by starting with water passing through the gun, then your gas supply might be limited or your carburetor gummed up. Pull off the rubber gas line that connects to the carburetor and see if gas flows.
Next, pull off the air filter and see if the machine runs good without air filter. You may have clogged air filter.
While the carburetor is exposed, spray WD-40 into carburetor. See if you can get engine up to full throttle while spraying WD-40 into carburetor. Keep spraying the WD-40. Keep the water flowing out of the gun.
If the engine throttles up all the way on WD-40 but won't run without it, then your carburetor is probably gummed up.
Our old power washer won't run with the choke set at full throttle. We just got into the habit of leaving the choke alone. We'd pull off the air filter and spray WD-40 into the carburetor so the engine would spark healthy without messing with the choke at all. And we kept the choke about 2/3 open all the time.
Oct 15, 2010 | Garden
Zl 600 1986 is hard starting
Ok, the correct proceedure for starting a cold engine is as follows, pull the choke fully on, and crank over the engine, DO NOT use the throttle when cranking the engine, when the bike fires and starts, slowly turn down the choke until a smooth fast idle achieved. The important thing to remember is, do not use the throttle while the choke is on, as this lets it **** in cold air, and makes for a harder start, remember the choke is there to restrict air flow, make a rich fuel mixture, for cold starting. If that does not work, then mabey u have a carby problem, make sure your choke is coming on.
Jun 01, 2010 | 1986 kawasaki ZL 900 A2 Eliminator
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Won't start, can't remember starting procedures and dont have manual
Make sure the fuel valve is on. Generally that means pointing down inless there is a diagram on it.
Turn the switch on.
Pull the choke on the carbuerator on full. There will be a picture of a butterfly valve set it so that it is closed. Pull the cord till the engine fires. let it sputter for a second, then open the choke. If the engine dies right away, do all of the above again but once it fires, only open the choke half way. once it warms up a bit open the choke completely.
Dec 22, 2009 | Honda Pressure Washer PSI 3000
Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
Sep 19, 2009 | Briggs & Stratton Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
