Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Lights will operate manually but clock doesn't operate.
There are no replacement clock motors for Malibu or Intermatic power packs.
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 20, 2011
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
Which fuse on a 2001 Carrrera runs the digital clock
The fuse center diagrams are in the owners manual, Porsche doesn't allow free downloads of the manuals, so we do not have one, otherwise i would share the info with you sorry.
Sep 05, 2012 | Porsche Carrera Cars & Trucks
Just intstalled a T104M according to the diagram and all the diagrams found on the web. The clock timer doesn't work. I can manually shut off the pump from the timer. I thought it was a bad tim
T104M is 208-277 timer mechanism that fits inside any Intermatic enclosure.
If voltage is not correct, then clock motor will not operate.
Since you did not say what voltage, I assume you have 240Volt pool pump.
Open following link to see the many ways to wire this timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
It is possible that you have the Load and Line wires reversed.
Line wire come from circuit breaker, and Load wires go to pump.
If the T104M mechanism is part of a control panel with more than one timer, and/or a freeze control, then re-post question with more specific information.
Jun 23, 2012 | Intermatic T104 24h 208-277v Mechanical...
I just installed a Wood 59018 timer, and when i try to turn it on manually, I hear the relay click on and then immediately off (the attached light turns on and off too). That's when the switch is set...
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jul 09, 2011 | Woods InWall 7 Day Digital Programmable...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Unable to set clock and or operate
You can go too the manufactures web site and download the manual for free as long as the microwave is under warantee............
May 02, 2009 | Microwave Ovens
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
