Question about Dayton (2C373) Fan
Dayton Attic fan running backwards
I have a Dayton attic fan that is running backwards. It is 110. How do I reverse it?
If the fan blade is on properly, then you probably have the wiring reversed. If you connect a line from motor to red box wire, and other motor line to black box wire, it will turn clockwise. If you reverse the wiring it will turn counter-clockwise ;-)
Posted on Jun 01, 2010
    President:
  • 2,976 Answers
Look at the blades. The flatest edge is the lead edge. If it isn't running backwards, turn the fan around.
Posted on Jul 26, 2009
    Genius:
  • 1,198 Answers
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Posted on Apr 29, 2009
I am not drawing air at my AC return\intake installed in ceiling. I just replaced the fan motor in attic. Is the rotation on this motor need G to be reversed? If so, how?
Chances are that there is a plug on the motor that switches from ccw or cw, usually black and white wires. If motor is running backwards reverse the plug
Aug 28, 2016 | Heating & Cooling
Creme colored know shaped like a whistle that the interior broke from the wall control on the Dayton Fan--where can I order a replacement?
If you cannot mend it otherwise or fix it up with a tinkering then the part is available only with Dayton.
So check up with their dealer or the serivce outlet if this is closer to you , or search the web for the nearest centre mentioning you area of resisdence.
Sep 24, 2010 | Dayton 7F67 Shuttered Attic Exhaust Fan...
I just bought a new motor and installed it but now
Centrifugal force.....If you replaced the motor only and not the blades, the blades are likely out of balance or possibly bent. Check for wobble and to see that the shaft is fitting tight inside the blade collar.If there is a bushing on the fan blade or shf itself, check it for play as well
Sep 13, 2009 | Dayton (2C373) Fan
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Dayton (2C373) Fan Logo
759 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
