Question about Kenmore Elite HE5t Washer
Getting a F35 code. The manual says I will need to call for service. I would like to know if there is another thing I can try first?
    Sergeant:
    Champion:
  • 342 Answers
Have you tried to unplug the unit at all? is the sytem even doing anything when you turn it on?
Posted on Mar 20, 2011
  • hahigdon Jun 28, 2011
    Yes, I left it unplugged for at least one hour. No lights come on now, the only thing that happens is it beeps when I push the power button. I was thinking of taking the lower front cover off to see if there is a reset switch.
  • Ryan Nguyen
    Ryan Nguyen Jun 30, 2011
    there could be a control board problem i would need to further investigate
  • Kenmore Master
  • 2,699 Answers
That's usually a pressure switch problem,remove the top panel and you should see it,there's a clear plastic line that goes to it,i've seen this before,took off the plastic line,blew into the line but not into the switch and put it back on and the machine ran fine,you can try this and if it happens again chnage out the pressure switch.next time send the model number,i can look up your machine and give you the part number.good luck
Suds and f35 code on kenmore elite he5t
get a service manual from the manufactures website
eric
Dec 24, 2017 | Kenmore Washing Machines
F35 ERROR CODE
had exactly the same thing happen; did you figure it out?
Would like to know if you had a big fee as won't bother if it is expensive to fix! Thanks Emma
Jun 16, 2013 | Miele KM 5753 Stainless Steel Electric...
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F35
f 35 is not in my info book . if you remove front panel 3 screws at bottom . inside there is a tec sheet with the fault codes. i would ck the clean out for the pump . it is right in front when panel is off . this may solve your prob .. .. mm
Nov 22, 2009 | Kenmore Elite HE5t Washer
What is code F35 on a whirlpool washer model wfw9600twoo
It's a general code for some electrical system problem. Ours flashes "SUD" before while the machine is on before flashing "F35" when it stops. I've tracked this done to being a problem with the pressure sensor switch in ours, and it appears to be either from obstruction from too many suds (like using the wrong detergent), or an actual sensor problem. I followed online advice to pull the tube and blow back to clear any suds out, and that cleared it for one cycle, but then the problem came back, so I'm either going to try some other things to clear before calling for a service person to replace the sensor. The part is W10156252 Switch, Analog Pressure Sensor, number 20 of the washer parts diagram.
Jul 29, 2009 | Whirlpool Washing Machines
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Washer Logo
299 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
