Power light pulsing on & off, TV will not come on.
    Sergeant:
    Champion:
  • 234 Answers
Usually indicates a problem with the power board and needs to be replaced.
Posted on Mar 20, 2011
87 chevy s10 blazer 2.8 has power to all related components but no spray from injectors cranks but wont start
-Use noise light to check each injector wire connector to see
If there is power there or not when you crank.
-If there is not power at all then 90% the cam & crank sensor are effect.
Good luck
Mai
Jan 25, 2017 | Cars & Trucks
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
I have the audiobahn a1801q and it pulses like a slow heartbeat. everything is hooked up fine. anyone have an answer for me? o yea the red light above the power is on but the power light only comes on when...
The amp is gone. if you have checked and double checked and it is hooked up fine. then the amp is toast. Contact the manufacturer to get a replacement if its under warranty.
Apr 14, 2010 | AudioBahn A1801Q Car Audio Amplifier
Amp won't turn on, red light on amp is flashing
DID THIS JUST HAPPEN ALL AT ONCE ? OR DID IT GRADUALLY HAPPEN? CHECK GROUND FROM AMP , INSTALL ONE FARAD CAP . STOCK RADIO ISNT REALLY HELPING , MOST AMPS OF TODAY TAKE A HIGHER SIGNAL FROM HEAD UNIT . ADD ONE FARAD CAP AND SEE
Jan 17, 2010 | Car Audio & Video
No puedo programar mi control ONE FOR ALL URC 7642 B00
At first you need to press the button of the TV (VCR, CBL or DVD)
After that you need to push the MAGIC button until the light(LED) flash 2 times.
Then press 991
The next step is to press the button of the TV (VCR, CBL or DVD) again and then the POWER button (Repeat this step until the TV (VCR,CBL or DVD) turns off.
And then you need to press again the MAGIC button and that's all.
Sorry for my bad english.
1.- Apunte el ONE FOR ALL a su aparato y pulse la tecla del aparato que quiere programar (TV VCR CBL DVD)
2.- Pulse y mantenga presionada la tecla MAGIC hasta que la tecla del aparato destelle dos veces. (la tecla del aparato que está programando se encenderá una vez y seguidamente dos veces). Suelte.
3.- Pulse 991.
4.- Alterne entre la tecla del aparato (por ejemplo TV) y la tecla POWER hasta que su aparato se apague.
5.- Cuando su aparato se haya apagado, pulse MAGIC. La tecla del aparato destellará dos veces. Ya esta programado.
Oct 17, 2009 | Emerson EWD2203 DVD Player/VCR
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Clarion apa4320 amp power light pulses
There is not enough power coming from you radio to power the amp. You might want to look in to a capacitor. What this will do is it will pull in the power and maintain a steady output for your amp to operate
Mar 18, 2009 | Clarion APA4320 Car Audio Amplifier
Power Button Blinks 3 times and then nothing happens
If the coolant spilled on a circuit board, there are changes that the board might be damage as this liquid is highly corrosive and also can conducts electricity while on the board.
What is the brand and model of the TV?
Apr 11, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
