Question about Riot MP3 Player
I lost the AC power supply for the rio riot hd 1200, could you help me the information about the caracteristics of this adapter (polarity and input) thak you very much
3 Suggested Answers
  • 230 Answers
SOURCE: Rio Riot
Have a try with this one:
http://www.digitalnetworksna.com/support/rio/downloads/rmm/Rio_Software_Ver260.exe
Although not officially available (or supported by DNNA) for the Riot, it happens to function with the Riot as well as newer players. Potentially later updates to RMM might break support with the older players.
Posted on Apr 20, 2008
lt_cmdr_bob_
  • 37 Answers
SOURCE: What size plug fits into a Rio Riot ipod so that I
You should be able to use the sync cable you charge it with along with a cigarette adapter that has usb ports on it. I hope that helps.
Posted on Oct 06, 2009
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
Hello! I have lost the original power supply for my Fanatec Speedster 3 Forceshock steering wheel; I have a universal adapter that should work; however, I don't know what voltage setting to set the...
I have this same wheel. The information off of the power supply: Model: AD-48130850, Input: 120V AC 60Hz 0.3mA., Output: 13V DC 850mA. Hope this helps.
Mar 15, 2011 | Video Game Consoles & Games
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Oct 06, 2009 | Riot MP3 Player
Input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
Apr 30, 2008 | RCA WHP150C Consumer Headphones
Riot MP3 Player Logo
206 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
