Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
There is power to the switch, however the motor will not come on. Is there a breaker on the motor?
    Sergeant:
  • 259 Answers
Check the brushes on the motor they would be under 2 plastic caps one for each brush. Also the motor might have a reset look for a button which is sticking out either on the side of the motor or top of the motor and push it in.
Posted on Mar 20, 2011
How do I bypass the circuit breaker on power sweeper rainbow e series?
If it is broken and will not stay engaged it should be replaced.
Feb 16, 2018 | Rainbow Vacuums
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
My series 90L suddenly stopped and would not restart. A check of the circuit breaker found it tripped. The vac would not turn on when the circuit breaker reset. Using an AC voltage sensor indicated power...
From the description it sounds as if there had to be a short in the unit somewhere. This is what would have tripped the breaker. the fact that it is not tripping could mean that there is a fusible link or that the wires or whatever have burned back from the short, and are no longer shorting out.
Jul 04, 2011 | Vacuums
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
My vaccum cleaner will not turn on...i checked the outlet and it works but no power to my vaccum
Some vacuums have a resettable circuit breaker in case of overload or switch in case of blockage. Both are usually a pushbutton type thing (like on a powerstrip). Find it, reset by pushing, and run the motor. Check for obstructions and for anything that could be preventing the brush-roller from turning. If the breaker or switch trips again there is a problem that needs to be resolved.
The manual might be helpful.
Oct 08, 2010 | Vacuums
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Jul 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
