Question about Amana Washing Machines
When starting the washer the water that fills the machine comes out with very little water
  • Amana Master
  • 2,694 Answers
Most likely the screens are filled with sediment.shut off the water shut off,mark the hoses so when you put it back you'll know where the hot and cold hoses go.remove the hoses and stick them into the washer,turn on the water and see how it sprays out to make sure it's not the house water problem,if it comes out with force you know it's the valve on the washer,you can try cleaning out the screens but it's best to change out the water valve on the washer.i've seen people clean the screens and then they still have problems with the valve,sediment gets in the valve,it doesn't seat right and the washer floods over,if you shut the water off every time you use it then you can try cleaning the valve out and the screens and see how it works but if it were my machine i'd change out the valve.call your parts store,give them the model number and there might be a p number too, and they will give you the right valve for your washer,next time send the model number with your question.good luck
Posted on Mar 20, 2011
    Top Expert:
  • Amana Master
  • 9,472 Answers
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Little water in Frigidaire front load washer
If the machine does not fill properly, it is usually because of a defective water level switch. This is also the cause for smelly clothes.
See also : It's underfilling
You can find replacement parts here.
or here Find Parts .
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Wd71 error 34
get a washboard and a jug
Feb 14, 2008 | Hotpoint Ultima WD72 Front Load...
Filling
have u got the echo-fill button on if it is it will only fill up with very little water other than that without seeing it cant say
Aug 12, 2007 | Zanussi IZ12 Front Load Washer
Need help
pump got nothing to do with water level only pressure sw vary it
May 10, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
