Question about CyberPower 550VA CP UPS 120V STANDBY GREEN8OUT 515R USB R CP550SLG UPS System
I have a cyberpower 550VA. The battery side is not working, the other side is. What should I do?? jmazepa@comcast.net
3 Suggested Answers
marmeto12
  • 155 Answers
SOURCE: My Cyberpower 550VA keeps turning
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Posted on Aug 25, 2011
epettingill
  • 175 Answers
SOURCE: Hi! I'd like to charge
Do it with the power on
Posted on Aug 29, 2011
The reset button is pushed in and therefore unable to reset it. Do you have any suggestions?
A faulty reset button. They are usually spring loaded. Replace the push button as it is stuck.
Jun 27, 2014 | CyberPower POWER,550VA,UPS,BK (CPS550) UPS...
Why is cyberpower 550va output voltage only 80 volts? Battery underload is 12+.
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
Jun 16, 2014 | CyberPower 550VA 330W UPS Green S System
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
It will not stop beeping when i play video games. As soon as i alt tab the beeping stops. This problem is driving me insane.
Your battery backup needs replaced.
When you fire up a game you draw more power
Your back up is not able to keep up.
Jul 02, 2011 | CyberPower 550VA 330W UPS Green S System
One side of my Cyberpower 525SL stopped working. When i press the red button the green light comes on, but goes off quickly accompanied by a beeping. The TV, dish, and vcr/dvd continues to work. Help...
Hi droger68,
The reason for the issue that you have right now with your Cyberpower 525SL is a bad battery. This means that some of the battery relay's component or relay has failed. You may contact the manufacturer if it's still under warranty. If not you may check this site they do have battery for your machine.
Hope this helps.
Thank you for using FixYa.
May 24, 2011 | CyberPower 525SL (CPS525SL) UPS System
Recently, we had a power outage. Our CyberPower 550VA battery back up doesn't seem to work now. It makes a low piercing sound that I can't shut off. There is a red button to press to stop it but it also...
Sounds like the inverter has an issue, maybe a short on the output or it can't get enough power from the batteries to run.
Generally these device are not repairable, and if they are, it could cost more than a new replacement unit. Depending on age, your batteries may need replacing. Check the battery voltage if you can. They'll either be 6 or 12 volt gel cells. Sometimes old batteries after a heavy usage, won't come back to life (take a charge).
R
Feb 02, 2011 | Garden
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
CyberPower 550VA CP UPS 120V STANDBY GREEN8OUT 515R USB R  CP550SLG UPS System Logo
463 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
David Payne
David Payne
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
