Question about Homelite Garden
I have a homelite string trimmer,I bought new fuel hose for it.the fule lines on it rotted! I'm confused ! the one that holds the filter ,where does it connect to? Thanks Bob
    Sergeant:
  • 259 Answers
If the primer is on the carburetor the filter went to the primmer the suction and the other line from the primer went back in to the fuel tank.
Posted on Mar 20, 2011
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Homelite string trimmer 275, which fuel line do you attach the fuel filter to?
its the line to the carb You have to find the one in the fuel tank Its more than likely the longest one If it hasnt been removed it will have the old filter attached to it already. if not it will be the longest one
Jun 15, 2011 | Homelite Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Briggs 4cycle 34cc ''Fource'' engine on string trimmer won't start
You may want to check the fuel line and the return lines; I had a similat problem on my 9 year old Weedeater featherlite and found that the fule line had rotted thru and the part of it along with the fileter was at the bottom of the fuel tank. Although your trimmer sounds like new, but this may be worht a try.
Sep 14, 2009 | Garden
Fuel Lines leak where they pass through opening into tank
i had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Jun 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel filter.
well i can tell you you gotta pull the filter with hose attached th ru the gas filler cap. i usually am able to get it when i tilt it towards the cap and grab it with some long bent needle nose.
Mar 25, 2009 | Homelite Garden
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Homelite string trimmer - gas
put it in the trash and buy yourself a new one nto the same brand.
Aug 09, 2008 | Electrical Supplies
Garden Logo
83 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
