Question about Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp
Cleaned and drained, reapplied air pressure-now losing water pressure and was a lot of sand before water stopped. Any suggestion as to what to look at????
  • 43,501 Answers
The check valve or foot valve which ever you have... has sand in it and it will not seal off and hold the water back....
Install another check valve by the pump, but make sure you also have a way to still get the air out and get it primed...
may have to pull all of the pipe to get it working...
heatman101
Posted on Mar 20, 2011
Electrolux washing machine w3250n water over flowing
Overflowing where? first thing check drain hose on the drain pipe and gasket. If there's a lot of water inside the tub, then check pressure switch and pressure hose. Pressure hose might have a hole in it. Pressure hose is a small hose about 5/16" inch diameter. Pressure switch controls the water. The air from air dome inside the tub pushes the switch thru the pressure hose to stop the water.
Nov 22, 2017 | Electrolux Washing Machines
Washing machine drain problem
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
Mar 09, 2008 | Washing Machines
My sand point well the water stops and starts again
You probably need to purge the pressure tank.
Well Pressure Tank Installation Instructions
Pressure tanks lose their Pre Charge pressure and have to be serviced. The well Pump needs to OFF. The Pressure tank needs to be emptied of water. There should be an air valve on the tank. Check the pressure .If this is a Bladder tank and Water comes out of the air valve- then the bladder is broken and the tank needs to be replaced. The Pre Charge pressure is set to 2 psi Below the cut-in pressure set by the pressure switch. If your system operates at 20-40 psi, The Pre Charge pressure will be 18 psi. Hope this helps.....
Mar 18, 2014 | Bur-Cam Pumps 750896 Water Shallow Well...
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
2004 Mitsubishi Endeavor - Only when turning left on the passenagers side: water leaks and a noise that sounds like sliding sand or a shifting sizzle. We had the air cond drain clean out but a week later...
Looks like the drain pipe/tube from ur A/C blower housing is blocked and need to be cleaned out!
Look for that rubber tube, pull it out and use any flexible wire to clean out the molds and grimes!
hope that clears up everything!
Taaah!
May 12, 2011 | 2004 Mitsubishi Endeavor
Pool had a lot of brown silt algae,cloudy put in correct amount of chemicals,back washed several times.pressure at 17 lbs goes to 21 in 1 hour.Tried to drain filter and I cant get the water to come out.I...
First I'm assuming we're talking about a sand filter. Back washing is the right thing if pressure increases.A 8-10psi pressure increase is the magic number where you must backwash. Be sure to run a rinse cycle too before returning to filter. If you want to clean filter you can buy chemicals that you add to your skimmer as you backwash. Follow their directions. If you do want to drain the water, open your basket cover on the pump and remove plug, this will allow air to enter the filter, so it will drain. It drains slowly. Not really necessary, except to winterize.l
Aug 03, 2010 | Hayward SAND FILTER, PRO SERIES
Lg wm0642hw drain hose in front is pluged with sand. When I tried to drain the hose so I could clean the filter I noticed the hose is plugged with sand. How can I clean the hose out.
That's a real pain. Even if you remove the hose, it is hard to clean out. You can get at the pump end of the hose by tilting the machine back and reaching under it. Replace the hose will save a lot of time, or I'd suggest next time you want to clean out your filter do this:
Pull the machine out about 18 inches or so away from the wall and tilt it back until the back rests against the wall. (front feet now up in the air) Now, all the water will be back at the back of the machine and you can remove the filter to clean it out without spilling water.
Aug 16, 2009 | LG WM0642H Front Load
I can not get vacuum pressure on my Hayward Sand Filter. I am using the Aquabug auto vacuum(which I've used over the last three seasons). When I fill the hose and put it into the skimmer port, I lose...
The filter is most likely not the issue at all.
When you lose vacuum pressure and see bubbles the problem is usually air getting into the line killing the prime. The most common place that air gets into the line is from the strainer cover on the pump. The clear lid on the front of the pump has an o-ring that after 3 years is probably due for replacement.
With a bad o-ring it's easier for the pump to draw air through the lid then water through 20+ feet of vac hose. Replace the o-ring, make sure it is lubed well with a non petrol based grease.
The only other issue that may cause this is a cracked or seriously warped strainer lid, which should be easy to recognize once it is removed to replace the o-ring.
Once this is done you should be fine.
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
Sand dollar sand filter has great pressure on backwash but has very low pressure on filter then after a short time does not have any pressure water does not move at all. I changed sand and cleaned...
Generally, if the filter loses pressure in the filter mode, you have an air leak somewhere. When the filter is low on pressure, check your pump basket area. If there is air in the basket, that is the problem. It could be a bad o-ring under the basket lid, or the air release on the valve, but it will need to be found. Check for drips around the equipment also.
May 16, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp Logo
106 people viewed this question
Top Sta Rite Industries Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sta Rite Industries Garden Expert? Answer questions, earn points and help others
