Question about Air Tools & Compressors
Switching off it self - Air Tools & Compressors
    Sergeant:
  • 194 Answers
MAY I KNOW THE MODEL NO
Posted on Mar 20, 2011
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Electrolux Slide in Range will not go into self clean mode because of faulty switch
Hello Iciapponi - From what you are describing it sounds like the switch that you are referring to is the motor latch assembly or thermal switch. Either or will need replacing in order the self clean mode function correctly. At this point, I highly recommend consulting a professional to accurately diagnosis the unit and to assist with the repair(s).
Feb 25, 2013 | Electrolux EW30ES65GS 30" Slide-in...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Vehicle is sluggish and not accelerating at it should. I got stuck in traffic once as the accelerator and break pedals blocked. Requested diagnostics (I am currently abroad with no Lincoln service) and...
First error code
P1650 - Power Steering Pressure (PSP) Switch Malfunction In Key On,
Engine Off Self-Test, this DTC indicates the PSP input to the PCM is
high. In Key On, Engine Running Self-Test, this DTC indicates that the
PSP input did not change state. Steering wheel must be turned during Key
PSP switch/shorting bar damaged
SIG RTN circuit open
PSP circuit open or shorted to SIGRTN
PCM damaged."
P1703 - Brake Switch Out Of Self Test RangeP1780 - Transmission Control Switch Out of Self-Test Range
Jun 15, 2011 | 2004 Lincoln Aviator
My ge hotpoint self cleaning 30" convention stove
sonud likr the little switch in the door lock is stuck when you put it on self clean there is a switch that puts it in to clean and now its stuck try to give the top at front a light bang and see if that jars the switch if not that will ned to be located and eather replaced or buy passed
Nov 11, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven sef clean latch locked but door is open and I cannot clos it. I inadvertantly urned it to self clean and openedthe door and the latch is locked in self clean position. How do I release the latch so I...
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Jun 16, 2010 | Kitchen Ranges
1997 venture van. Fan for heat and A/C not working
Check the fuse and then the switch it self, if the fuse and switch is good. Then check the blower resistor and blower motor it self. I'm leaning towards the switch it self since you mentioned that it was sporadically and on the highest setting would by pass the blower resistors. Good luck and if it's not the switch then it's going to be the blower motor it self. Auto Zone has them in stock and can give you the step by step instructions for you to get the job done with common tools.
Nov 12, 2009 | 1997 Chevrolet Venture
A/C won't work 03 Acura RSX
General Troubleshooting Information
How to Retrieve a DTC
The Climate Control Unit has a self-diagnosis function. To run the self-diagnosis function, do the following:
1. Turn the ignition switch OFF.
2. Tu rn the fan switch OFF, the temperature control dial to MaxCool (60.F or 18.C), and the mode control dial to Vent.
3, Turn the ignition switch ON (ll),then press and hold the recirculation control switch. Within lO seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times and the A/C indicator comes on, then the self-diagnosis will begin. About 15 seconds later, the self diagnosis will finish and the Ay'C indicator goes off. lf there is any problem in the system after finished self diagnosis, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 1 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and t5), the A/C indicator will blink the DTC. lf no DTCs are found. the indicator will not blink.
d35f123.jpg 695f305.jpg5d11822.jpg Resetting the Self-diagnosis Function
Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions.
Jan 13, 2009 | 2006 Acura RSX
Self cleaning
I have had the same problem on our ge oven for years.
I found that there is a micro switch that does not switch back to bake mode after self cleaning. If you move the lever to self clean and back to normal VERY SLOWLY, the switch may work correctly for bake. We have been doing this for years. The switch can be seen from the from behind the lever mechanism. I would like to replace ours, but I need to figure out how to get to it. If anyone knows how to get to the switch to replace it, that would be great.
Jan 12, 2008 | GE JBP90 Electric Kitchen Range
Air Tools & Compressors Logo
42 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
