Question about Ahead Software Nero 6.0 (60045) for PC
Compatibility issues - Ahead Software Nero 6.0 (60045) for PC
  • 154 Answers
Which version of windows you are using? either 64bit or 32 bit.......read it in mannual for which version of windows it works.........
Posted on Mar 21, 2011
Adobe Photoshop Elements 4.0. Unable to install this programme on Windows 7 Home Premium system due to 'known compatibility issues'. Is there a solution to this problem?
Windows Vista Application Compatibility Updates are software updates that address common application compatibility issues in Windows Vista. Microsoft releases Windows Vista Application Compatibility Updates regularly.
If you want to immediately install this update, follow these steps:
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, click All Programs, and then click Windows Update.
  2. In the navigation pane, click Check for updates, and then follow the steps to install all recommended updates.
Sep 22, 2011 | Adobe Computers & Internet
Tip
Windows Compatibility Issue for Older Programs
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and then select the Windows version you know the program worked on before. This way the program will be run as it would run under Windows XP or Vista, 32 bit or 64 bit.<br /> <br /> You can find more about this Compatibility issue on <a href="http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows">http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows</a>
on Dec 22, 2010 | Computers & Internet
I'm using windows 7 32-bit. When I try to install dragonshard from autorun or setup.exe nothing shows up. I've tried compatibility mode, but nothing works.
If it is an older title it may have compatibility issues with windows 7. For example I have Diablo II for pc and i simply cannot run it in windows 7 because of compatibility issues.
Mar 23, 2011 | Atari Dragonshard for Windows
I have software for 32 bit computer and would like to install program on new 64 bit computer. When trying to install American Greetings Card program, it states compatibility problem. What can I do to...
If a program cannot be run under Windows 7 64 bit because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Dec 19, 2010 | Microsoft Windows Vista Ultimate Edition
Is there a Creatacard CD compatible for Windows 7?
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 05, 2010 | Broderbund American Greetings Creatacard...
Windows 7 Professional + compatibility with Broderbund Print Master Platinum Version 18
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Broderbund Print Master Platinum Version 18, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 20, 2010 | Broderbund PrintMaster Platinum Version 18
Windows 7 compatibility
If a program cannot be run under Windows 7 because of compatibility issues, which is the case withMicroProse Civilization 2: Test of Time, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website
Jul 07, 2010 | MicroProse Civilization 2: Test of Time...
What other printers are compatible with 1270
There are no compatibility issues with printers. There are compatibility issues between printer models and operating systems and betweek printers and ink cartridges, The X1270 is several years old, but it uses the same cartridges as a number of other Lexmark printers.
Jun 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can u help?
IF there is a compatibility issue Then why not use the compatibility wizard.
Click on your start button /ALL programs & then upto the accessories menu & then click on the Program Compatibility Wizard.
Try it
It is a well missed program But sometimes you never know.
You could also do a google search to see if there is other people with the same problem
Or you could search for a fix
for eg.
Vista Compatibility error fix.
Dec 27, 2007 | Computers & Internet
Ahead Software Nero 6.0 (60045) for PC Logo
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
