I bought speaker circut breakers (70 watt) to protect my tweeters from blowing, as my amp is a GFA555 200wpc and my speaks are 150watt Wharfedale modus ONESIX's. I put them in line on the positive side coming from the crossover to the terminal closest to the side that has the writing on the breaker then out the other to the tweeter. while driving them a bit hard I blew another one yesturday, are they hooked up wrong?
  • ideal_dls10 Mar 20, 2011
    I purchased these breakers from parts express, they are 1.0 amp current hold. They state that when they reach 200% of rated hold for 5 sec. they open. My Adcom GFA555 has instantanious distortion alert lights which vaguely light intermitently which is supposed to be acceptable. I have ordered 0.85 Amp breakers lowering the output wattage per their spec's to 120 watts. they offer 0.7 A and 0.5 A should I order one of these? lowering output wattage to 100 w and 80 w respectively.
    these breakers are 1.0 Amp they offer .85 .7 .5 Amp versions. I do not believe it is a distortion issue as my Adcom GFA55 has distortion alert which seems to function properly as I see intermitent light which they say is normal. What in your professional opinion should I do to protect these tweeters, as I really like these speakers otherwise
    Brigadier General:
  • 8,546 Answers
Your hookup is electrically sound but perhaps it is distortion that is killing the tweeter rather than raw power. And I doubt there are many consumer tweeters out there that could handle 70 watts in their pass band anyway.
I've never heard of a circuit breaker that was rated in watts. Amps (current) maybe.
Peruse this discussion, especially the last comment...
http://www.talkbass.com/forum/f15/tweeter-wattage-ratings-what-do-they-mean-661897/
What IS the rated power dissipation spec for the tweeters youi keep killing?
Posted on Mar 20, 2011
  • David Dunn
    David Dunn Mar 21, 2011
    5 seconds of overload is a long time in the tweeter world.
    Your crossover could be failing to filter the lows. Guessing at an acceptable current rating is going to be hit and miss.
    See this discussion. Another user had his own fix (solution 2).
    http://www.fixya.com/support/t353703-wha...
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
I bought a pair of Mordaunt Short Qviano 1 speakers from Richer Sounds 18 months ago and now find that the tweeter in both units has failed. The amplifier I am using is rated at 70 watts which is within...
Specs refer to UNdistorted sound. Send square waves to any speaker and it will die eventually, perhaps even the amp.
You are more likely to blow up speakers with an under-powered amp pushed to hard than a monster amp running well within its capacity. Distortion percentages rise vertically once the amp's useful range is exceeded. Tweeters are usually the first casualties.
It's tweeter hunting time.
http://www.mordauntshort.com/support.php
http://www.mordauntshort.com/assets/documents/Aviano2TechSpecs.pdf
Aug 10, 2011 | Audio Players & Recorders
Something blew-up in the speaker cabinet. it turns out it's the protective lamp overload. May I know if you carry that? Thank you
Usually that lamp part ONLY protects the tweeter. If the woofer doesn't generate sound, then you probably blew the speaker as well. This speaker is rated at 250 Watts PROGRAM... that means your amp you drive this with should be no bigger than about 150 Watts RMS or you can blow the speaker. You should be able to get reasonable sound for a 20 foot square room with this unit.
Aug 09, 2011 | Samson RS12 HD PA Enclosure
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
What size fuse do i need to use for my speaker protection kit
This will be based on the 501 model as you did not give a model Also I am assuming speakers are 8 ohms which I have no firm information for the Tannoy, but they should be marked when you open the unit. We are allowed 40 watt RMS for the woofer and 20 watts RMS according to the specs. They do not tell us what impedance the speakers are so we will do calculations based on 8 ohm speakers... if yours are different, then recalculate; P = I^2 * R so for 40 watts and 8 ohms then I squared = 5 or the current is about 2.3 amps max... You COULD use a 2.5 amp fuse, but if they were my speakers I would use a 2 amp fast blow which gives a bit of margin for the woofer. Now for the Tweeter we have I squared is 20/8 so this comes out I squared equals 2.5 or taking the square root we have 1.58... you could use a 1.75 amp, but if they were mine, I would use either a 1.5 amp or even a 1 amp as the tweeters seem to get blown in these. ALL of these calcs are based on the specs of power for the 501 model and ASSUME 8 ohm speakers... Recalculate if your units have different impedance thaan the assumed 8 ohms.
Jun 22, 2011 | Tannoy Studio Monitor Speaker Protection...
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Jul 24, 2009 | Car Audio & Video
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
My tweeter in my atlantic 500 isnt working.
If you did not hear any sound from the tweeter, but you did on the new one, the old one is bad my friend. I tried to find an original replacement for you but I could not find it. I did however speak to someone on your behalf about your problem. I was informed that if you call them at 1-877-732-5374 and give them the dimensions, they can get you a nice not too pricey replacement that should sound good to you. I was told they go for about 70 to 100 bucks. Good Luck
Jun 05, 2007 | Wharfedale Atlantic 500 Main / Stereo...
Open Questions:
75 people viewed this question
 Grubhead
Grubhead
