Question about Frigidaire Affinity ATF7000E Front Load Washer
It walks all over, does not matter the size of load.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Make sure that you properly removed all of the shipping bolts and packing material when you installed the washer. This could cause the machine to vibrate. I provided an image below regarding the removal of the transport bolts and packing of the washer. I also provided a link below for the entire installation manual for your washer. Carefully review this entire manual to make sure that the washer is properly installed.
If the washer is on unstable flooring, it will vibrate and walk. This type of washer works best when it is on a concrete slab. If it is on a wood floor, you may need to reinforce the foundation to eliminate vibration.
Posted on Mar 20, 2011
Washer goes off balance so easily, no matter the size of the load, from towels to shirts. We checked the washing machine itself is level. It's so frustrating to have a small to medium load cause the basket...
The tub is out of alignment.The suspension springs are weak and must be tight, the tub must not shake,if so the dampers are faulty.
This suspension must be so rigid that it must not shake around freely . check the pulley arangement , the bearings at the bottom spindle, if out of balance. If there is any anomalies in this ddrive section it must be observed and checked.
A careful analysis is most important to having a first hand information.
Aug 23, 2010 | Maytag HAV2557 Top Load Washer
WASHING MACHINE IS OVER FLOWING. THE LOAD SIZE IS
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 16, 2010 | GE WJSR4160DWW Top Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Ratchet and clank size matters will not load on psp
upgrade your psp to the latest firmware of the psp.. connect by going to update psp
Feb 01, 2009 | Sony Ratchet and Clank: Size Matters for...
Fridgidaire front loading washer
Open the bottom and check to see if the shocks are good.
Apr 09, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer Logo
184 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
