Question about Kenmore Side by Side Refrigerator
Kenmore Side by Side, hear a clicking sound every 10 mins. or so; freezer starts defrosting several times a week then freezes again. What is the problem?
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
Kenmore refrigerator freezer stopped freezing and cooling then several hours later started working again ?
Look at what time the defrost timer is set to. It may just be as simple as resetting the time or you may need to replace it .
Aug 04, 2014 | Refrigerators
KENMORE MODEL 253.54362409 KEEPS DEFROSTING
Sounds like your defrost sensor is acting up because after you unplug it then it works for a week or so.
Dec 25, 2017 | Kenmore Refrigerators
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Kenmore side by side refridgerator ice around freezer fan
I am looking up your refrigerator to see the right parts. Sounds like the defrost cycle is not happening. look for a defrost or adaptive defrost board. Check your model number again because I am not able to find the number listed. I will continue to check for the correct refrigerator and if you find a simple defost timer turn it clockwise slowly until you feel and hear a click. If you do and you may hear the elements heat up inside the freezer. If that happens just put a new defrost timer and you should be set. Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
My Kenmore Fridge (bottom freezer type) not freezing
Look for problems you can see. Check for frost on the back wall of the freezer, If you find frost on the back wall locate the defrost timer and rotate the clutch head screw clockwise SLOWLY until you hear one click. With the timer now in the defrost position you will hear sounds in the freezer compartment such as expansion, sizzling, after a few minutes. If after say 25-30 minutes the system does not return to cooling mode ( Compressor starting) rotate the timer again SLOWLY until you hear a second click. This would indicate a bad defrost timer. If you get no defrost your problem could be a defect in the heater circuit such as an open heater or defrost thermostat. Normal defrost time would be 18-22 minutes.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Works Off and On
Do you hear any clicking during the time it is not working? The start relay on the compressor may have a bad connection internally.
Oct 22, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
