Question about Hotpoint Ovens
Hotpoint cooker ew93 coming up with fault number 17
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Light is flashing reading Err 08 on electric oven model EW93 cuts main oven off?? why is this
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Mar 18, 2011 | Hotpoint Ovens
Hotpoint cooker manual to suit model uy46x
If you are in the U/K, then try the following site.
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on-----HOTPOINT USER MANUALS.
Then in the search box enter your model number and download the instructions.
Dec 01, 2010 | Ovens
I HAVE A HOTPOINT DOUBLE OVEN COOKER EW71. THE GRILL SWITCH IS PLAYING UP AND I NEED A NEW ONE. CAN YOU ADVISE ON THE PART NUMBER PLEASE
The part number you require is----------6204036.
Should you require the knob as well, the number is---------6201888.
These can be ordered directly from Hotpoint.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ovens
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
61 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
