Question about Honeywell Heating & Cooling
How do i operate a honeywell standard nonprogrammable t8400 digital thermostat?
How do I adjust the day.
Posted on Aug 03, 2008
Tip
Programmable Honeywell
A Programmable Honeywell Thermostat is a great investment for you to make for your heating and cooling system. A Honeywell Thermostat will provide you with the best in comfort and dependability for many years.
Many people when they think of Honeywell Thermostats think of the old round T87 thermostat that has been one of the most common thermostats for years and years.
Today they have those thermostats in designer colors and they are still made and used in many situations. But the manual thermostat is quickly becoming a thing of the past. With the rising costs of fuel the Programmable Honeywell Thermostat is becoming more and more popular. Programmable Thermostat Honeywell is even one of the most popular searches when it comes to thermostats.
The VisionPro thermostat line has quickly become one of the leading digital programmable thermostats on the market to today. The ease of programming this thermostat and the touch screen interface has made it a very popular choice for many people. There is a variation of this thermostat for virtually any possibility that you can think of. The FocusPro line also is a very good choice at a bit less cost. There is a basic Pro line and also even a digital thermostat in the traditional round configuration. Both digital programmable and basic digital thermostats are available for line voltage control of electric heating.
Along with the thermostats you now are able to add remote outdoor sensors as well as install you thermostat in a remote place and run a sensor to the space you are controlling. For many years these capabilities were standard for commercial thermostats, but now they are a very real possibility for home use also. With an outdoor sensor these thermostats now have the capability to turn off your heat pump and start you backup heat a certain preset out door temperature. In the past many systems have been installed with complicated electronic to do what a thermostat can do very easily.
The Programmable Honeywell Thermostat has come a long ways in the past few years. The changes have made this thermostat capable of doing many unbelievable things. If you are looking to replace your old thermostat, carefully compare the many thermostats on the market and then pick the one that will meet your needs the best. For many the Honeywell digital thermostat will be the best choice, giving them great flexibility and reliability in one thermostat.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
on Jan 15, 2010 | Heating & Cooling
Honeywell TH5110D1006 FocusPRO NonProgrammable Thermostat Is there any trick that can make it so I can keep a child from messing with the thermostat Anything even if its just disabling to buttons We leave...
I believe you can set a range stop in installer mode, the instructions are here but if you have difficulty ask your installer as if you don't know what you are doing you could stop your system working by changing the wrong settings in installer mode.
https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-2021ES.pdf
Apr 02, 2014 | Heating & Cooling
The fault symbol is flashing and the red light is on, how do I determine the fault and how to reset after fault is found?
You can get an operators manual on Robertshaw's web site. The fault could be that it's too co;d outside for the heat pump to be efficient. Once you get the manual you'll be able to find out exactly what's wrong.
Mar 26, 2014 | Robertshaw 300-208 digital...
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
Need coleman thermostat schematic: LR1620 ;T874R1368 Base Q674L
http://www.iaqwholesale.com/manuals/IAQmanuals/Honeywell/Thermostats/NonProgrammable/ManualNonProgrammable/T874/60-2485.pdf
Dec 02, 2010 | Coleman Heating & Cooling
Hi, I have a Honeywell Thermostat T8400 (non-programmable.) The screen is blank and will not come back on. I've unplugged it from the wall and turned the electricity off and on in an effort to reset it. It...
if you thermostat doesnt use batteries and it has no power, that means there is a problem with the air conditioing system itself. 90% of the time it is a safety switch such as a float switch (drainage problem), which cuts the power to the system to prevent damage to your house from condensate water leakage or just further damage to the system itself. Call the a/c guys, this is going to require expertise.
Oct 09, 2009 | Honeywell Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
