Question about Coby TF-DVD7307 Portable DVD Player
Where can I purchase the cable to connect my dvd player to my tv..I need the one that has a pin on one end and a white/yellow on the other
    Master:
  • 346 Answers
Hello hyegee -- You could probably get one directly from the manufacturer at a way over the top price. The cheapest and easiest thing to do is to get two generic cables at any store that carries electronic accessories.
For audio you need a stereo 3.5 mm male to stereo RCA jacks male cable. For video you need a simple 3.5 mm video male to RCA jack male video.
Here is the graphic from the user manual. Yours new cables would hook up the same but just be two instead of one cable:
Good Luck and thanks for using Fix Ya
Mikeywaf
Posted on Mar 20, 2011
I plug the white, yellow and red cables from the dvd player into the back of the tv but it says "no signal". I changed the input to Component 1 then I tried the other plugs too but still get the...
Hello
If you have connected the red, white, and yello video cable connection right correct to the respective pins; both at DVD and TV end, by selecting the input to Video-1 or Video-2, you must get the logo of the DVD player on the TV screen. Please not that whether you have 'Power ON' the DVD player. If the connections are good, the logo must be ther. Otherwise check the continuity of the RCA cable, of it may have damaged[shorted]. Try replace with an other cable. OK.
Aug 15, 2011 | Apex Digital LD4088 LCD TV
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How do i connect my dvd player?
It depends on what outputs your DVD player has and what inputs your TV has.
If your DVD player has HDMI outputs and your TV has a HDMI input then you will need to purchase a HDMI cable and connect the 2.
If either your DVD or TV does not have HDMI then you will need to move on to either a component video cable which has 3 cables on the end which are colored red, blue and green. You will also need to connect for audio which is a cable with 2 colors, red and white.
There are also s-video and the regular old way of connecting which is a 3 cable design which has a yellow end for video and a white and red end for audio.
If you need any more help or can offer more info on what connections your TV and DVD player have then I would be happy to help.
Jan 12, 2009 | Samsung LN26A330J LCD TV
Connecting DVD player to Viewsonic TV
You will use component video cables.  They come in threes and all they require you to do is connect the DVD output with the TV input and match the cable colors on both ends.  They will be red, white, and yellow.  The yellow is the video, and red and white are left and right audio.  If your TV is too old to have stereo audio, only one (red or white) audio cable needs to be connected.  It doesn't matter which.  The yellow cable always needs to be connected.
Another option, but a slightly less common one, is to use a single AV cable to connect the two.  The reason this is less common is because most newer TV's do not have AV input, and newer DVD players do not have AV output.  If it does, however, this is the most simple, and you probably wish to take advantage of it, so you have a connection available when you purchase a newer unit which does not have AV.
Aug 13, 2008 | JVC XV-N212 DVD Player
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Coby TF-DVD7307 Portable DVD Player Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
