Question about D-Link DIR-632 8-Port Wireless-N Router (790069336263)
I have a D-LINK 632. The wired ports work perfectly. But I cannot connect to the Wireless portion of the network. I am running Windows XP (SP2). It (the wireless) see the router and see it is a full strength the signal but after I type in my SSID passkey it tries to connect but after a time it gives up.
  • 4,281 Answers
For that first uninstall wireless driver then reinstall it.
If still same then you need to change channel type in router.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->Channel type set it to 3 or 6 or 11 then save and restart .
Let me know if you need further assistance. Thanks for using FixYa.
Posted on Mar 20, 2011
Reinstalled wp on Gateway 400vtx and now the wired internet connection drops out in about 1 min and I get noe connection on the wireless.
Thank you for your kind words, we try very hard to resolve people's problems so a solution can be reached.
Apr 06, 2012 | Gateway 400VTX-3501335 Notebook
Belkin N+N storage router doesn't work wirelessly
Hi, I had something like that with my Belkin Router N+N with USB F6D6230-4 V1, only I had a configuration wit a wired XP pc, Wireless XP and Wireless Vista. With both XP pc’s it was really plug and play, but with the Vista pc I had some problems to access the on the router connected USB drive. The Vista pc was connected to the network, and had Inet access. Other shared (network) drives were accessible on the Vista pc.
The first thing I tried was if I could access the drive trough its IP address, (\\routerIP in my case \\192.168.2.1), and I did get a question for a username and password. The only thing is that I tried all the regular names like Admin, Administrator, and so on, with my password but I did not get access.
On the internet there was no help to find for this model router on the Belkin websites (diverent country’s), the data on the Belkin websites is out of date, there is no support to find for new models. ………. So finely I did took the phone and did call the support desk…
Solution to my problem:
The problem seems to be in the Belkin storage manager program, that program works not correct under Vista. When I enter the routers IP and use the username “guest” without a password, it get access to it from my Vista pc. The follow thing I did was press the right mouse button on the drive, and press on “make connection” So..
\\RouterIP
Username : guest
Password : none
Hope, that this is also the solution to your problem.
Greatings
Martin,
The Netherlands.
Feb 23, 2010 | Computers & Internet
My wireless adaptor can not find my wireless router
Please check tour wireless adapter if its working and properly installed in your computer. Here's how to do it;
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
If your wireless adapter is not working and installed properly, you have to re-install the wireless adapter software driver. When the wireless adapter is already properly installed you can follow this steps below;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 10, 2009 | NetGear WGR614 Wireless Router
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Motorola SBG900 - network cannot see hardwired computer
Try to logon to the configuration page of your router and from there you can able to setup the Local Domain Name on it for your network.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Driver for Broadcom 802.11g Network Adapter #2
HI Gocha,
Try to get this driver from Intel website it might help you. Intel(R) PRO/Wireless 2200BG Network connection.
Regards,
K.Loges
Nov 29, 2008 | Computers & Internet
Broadband connection issue w/ XP SP2
Upgrade the computer to SP2 and then check the firewall settings after the upgrade. Turn off the firewall and see if you can connect then. I you still have a problem I would check the computer for viruses with a free online virus checker or with Trinity Rescue CD.
Nov 09, 2008 | Microsoft Windows XP Home Edition
I cannot creat a wireless network
What OS are you running? If XP:
There are two ways to configure your wireless router: using Windows Connect Now and manually.
• If you don't have a router that supports Windows Connect Now, you need to manually configure your router:
1.
Using the network cable that came with your wireless router, temporarily connect your computer to one of the wired network ports on your wireless router (any port that isnt labeled Internet, WAN, or WLAN).
2.
Turn your computer on; it will automatically connect to your router.
3.
Open Microsoft Internet Explorer and type in the address to configure your router, as described in your router's instruction manual.
4.
Create a password if a prompt appears. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
Here is the general login user and passwords
3Com
http://192.168.1.1
admin
Admin
D-Link
http://192.168.0.1
admin
(leave blank)
Linksys
http://192.168.1.1
admin
Admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three items:
Set your wireless network name (known as the SSID) to something unique that does not identify your name or address.
Enable Wi-Fi Protected Access 2 (WPA2) encryption to help prevent uninvited guests from connecting to your wireless network.
Note: We don't recommend using WEP. WPA-2 is more secure. If you try WPA-2 and it doesn’t work, we recommend that you upgrade your network adapter to one that works with WPA-2.
Set your administrative password to prevent others from configuring your router.
The exact steps you follow will vary depending on the type of router you have. After each configuration setting (SSID, WEP, and administrative password), be sure you click Save Settings, Apply, or OK to save your changes.
Note: The pictures in this section show Linksys wireless equipment. Equipment from other manufacturers will vary in appearance. For example, to save your settings in Linksys, you click Save Settings. Other equipment may have a different display, and you may have to click Apply or OK.
SSID or naming your networkA service set identifier, or SSID, identifies your network. Choose a unique name that you're confident none of your neighbors will use, but don't specify your name or your address. This is not a security tool, so you don't need to make the SSID complex.
Help prevent uninvited guests from connecting to your wireless network. To learn how, read Implement WPA2-Personal wireless security on a Windows XP SP2-based computer.
Administrative passwordThe last configuration change you should make is to the administrative password. Just like any other password, the administrative password should not be a word you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
Connect your computers and devicesIf your computer does not have wireless network support built in, you can install a wired or a wireless network adapter. Windows XP will automatically detect the new adapter and might prompt you to insert the CD that came with it. The on-screen instructions will guide you through the configuration process.
Windows XP Service Pack 2 (SP2) is not required for wireless networking, but it does make setting one up much easier. SP2 also helps protect you against viruses, worms, and other Internet intruders. To install SP2, visit Microsoft Update. The steps below apply only if you're using SP2. Windows XP will show an icon with a notification that says it has found wireless networks.
To connect your computer to your wireless network
1.
Right-click the wireless network icon in the lower right corner of your screen, and then click View Available Wireless Networks
2.
The Wireless Network Connection window appears and displays your wireless network listed with the SSID you chose. If you don't see your network, click Refresh network list in the upper left corner. Click your network, and then click Connect in the lower right corner.
3. Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
Windows XP will show its progress as it connects to your network. If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key—click Cancel and return to step 3.
After you're connected, you can close the Wireless Network Connection window. Now you're ready to browse the Web wirelessly. You can also create a wireless network in your home that connects your computers, printers, cameras, games, and other accessories for easy access and enjoyment.
Apr 21, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link DIR-632 8-Port Wireless-N Router (790069336263) Logo
300 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
