I have a Crosley CR248 CD Recorder and mistakenly put a blank DVD in the CD recorder and it will not eject. The unit is "locked" in "CD loading " mode and will not allow any other functions to operate. How can I get the blank disc out of the recorder? Thank you for your time.
  • 604 Answers
Look for a small hole near the front of the cd drawer, use a pen to push the small button inside, and the disk should come out. some cd recorders don't have the button, but they are inside, you need to open the case to get at it and the push it to eject the cd/dvd one other thing you might try, is to unplug the unit from the wall (power) and then plug it back in, when it first powers up, push the eject button and it may come out then
Posted on Mar 20, 2011
How do I get the cassette draw to open on my Crosley Songwriter CD Recorder CR248?
Inside the unit probably is a small rubber belt which will operate the draw, it has possibly fell off or snapped. It will just need to be replaced. Look on e-bay for a replacement belt. You can get loads of different sizes cheap from China.
Jan 04, 2018 | Crosley Audio Players & Recorders
Need owners manual for a CROSLEY cr248 cd recorder /cassettes to cd & records to cd
Type " Crosley CR248 User Manual " in your search engine and it will bring up sites to get manual.
Jun 10, 2015 | Crosley Audio Players & Recorders
CD will not finalize
No-way should it take that length of time to finalise anything. My DVD recorder only takes about 3 minutes at the most to do a 4 hour disc! CD are only 80 minutes max. I suspect you have an electrical fault on the unit. I would take it to the nearest Crosley Repair place.
Mar 27, 2014 | Crosley CR248 Turntable
I lost my manual that came with my crosley cd recorder?
If you go to your Internet home page and type "Crosley Songwriter CR248 user Manual" into the search window and press your enter key, you will be taken to
a page where you can download a copy of the manual.
CFJ
Dec 06, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Why does my crosley turntable/cassette player/cd recorder cuts off when I play it?Whenever I try to record from a cassette to a cd it cuts off.
I would suspect that you have a bad record laser in the CD recorder assembly, this is common, and this is usually what it is. To this end you would need to replace this unit's laser assembly, it will/may still play a CD OK, but will not write to the CD, as they are two separate lasers. So if you wish to try to repair you will need to contact Crosley and ask them what to do, ask for a referral to an authorised service center or perhaps even return it to them? In any event ONLY ask for a "Quote" first and see how much it may cost before proceeding.
Oct 15, 2011 | Crosley CR248 Turntable
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Crosley CR2406A will not record CDs properly.
I had this problem when recording CD-Rs. I switched to CD-RWs and didn't have the problem again.
Feb 18, 2009 | Crosley CR248 Turntable
Crosley CR245 wont recognize any cd - blank cd-r or music cd
Check the manufacture's website for trouble shooting or firmware update
Feb 02, 2018 | Crosley CR248 Turntable
Hi, the crosley will no longer record onto any music cdr/rw. It will indicate that the cdr is blank-i know it is- then the zeros/record appears but no recording takes place. thanks if you can help.
I turned it off for two (2) hours - turned it on and it worked. Apparently this unit overheats after one session: one (1) cd-r per session then shut-down.
It is worth it, when it works, because my lps have no hiss when finalized.
Sep 05, 2008 | Crosley CR248 Turntable
77 people viewed this question
 Grubhead
Grubhead
