Question about Vitamix 5000 Work Top Blender
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
  • michael_d793 Apr 10, 2011
    I took it to an appliance repair shop,who did the work for $45.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Posted on Apr 10, 2011
Testimonial: "Thanks,I took it to a local appliance repair shop,who did what you described for $45."
  • vancetom Apr 11, 2011
    If you are a bit handy you can buy the bearings and seal from an auto parts store or online and do it yourself costing probably about 7 to 12 dollars for the bearings and seal. Did you ask repair shop to give you the old bearings/seal? You can use them for a sample t order for next time.
    Vance
  • michael_d793 Apr 11, 2011
    No,it never occurred to me.They've probably thrown the old seal/bearings out by now.I DID ask the fellow what he did to remove the bearings,but he was busy,and I didn't want to hold him up.
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Leaking blender jar
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
ELECTRICAL SMELL AND SOUNDS ROUGH
It sounds like you need to replace blade & bearing assembly in the beaker, change it before you wreck the motor.
Aug 23, 2012 | Vitamix 5000 Work Top Blender
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
I need to replace the speed control potentiometer. How do I open the case on this machine?
Hi there. I know you were looking for an answer 5 months ago. I didn't see the correct procedure listed. My speed control just bit the dust. Anyway, here goes: Pull off the rubber cover where the container sits. You'll see 4 phillips screws, unscrew them (you can leave them in place). Next, on the black drive wheel in the center, look to find a small triangle molded into the outside of the ring. Line it up with a small slotted opening just under the drive wheel. Use a small allen wrench which fits in and unscrews a set screw. You can lift off the drive wheel. Now you have to pull the top off. On mine, it took some time as I was trying to be careful not to break anything. With persistence the top will separate from the base. My super 5000 has a 2 wire speed control knob. Hope this helps if you haven't gotten an answer elsewhere or taken it to the shop.
Sep 16, 2010 | Vitamix Super 5000 Work Top Blender
Our wet container smoked and smelled, the taste of plastic got in the shake..There is no "visible" trouble Do you think it could be just the agitator or do you think it could be the motor Model 5000
first take off the container and on the under side bottom of it that sits in the unit is a drive gear see if you can turn it with your fingers also at the bottom of the wet container inside it is a blade that spins in a bearing and this bearing gets tight or even seized up at times strip out this bearing and renew it and the seal but watch your fingers as the blade is very sharp rap it in a thick rag to hold it in your fingers,,,,
Jun 06, 2010 | Vitamix 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Blade turns with difficulty
Check the blade assembly it may be worn out.
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
1,573 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
ray gallant
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
