Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
My fridge dose not work . It's not cooling. - Magic Chef MCBR360S Stainless Steel Compact Refrigerator
  • Magic Chef Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
Hi please help on RS21NJSH Twin Cooling Fridge It works fine for an hour later on only compressor kicks off and it dose not come on unless you disconnect the plug from the socket and plug it in back
You need to make a service call to an authorised repair centre to have someone come and check it out. It is unlikely there is anything you can do yourself.
May 23, 2016 | Refrigerators
Frigidare model # frs26znh freezer side works good refrigerator side dose not get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 13, 2011 | Refrigerators
Frigidare frs26znh freezer side works good refrigiator side dose not get cold
heatman101
Jul 13, 2011 | Microwave Ovens
I have a samsung refrigerator rl33sbn . Where the freezer is at the botton, the freezer cooling where frost build up on the condensor the refridgerator remain warm. I check the fan is good when i tested it...
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 08, 2011 | Refrigerators
I have a chefmate small freestanding refrigerator and it does not cool and the fan dose not seem to work. What can I check for or how can i trouble shoot?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Refrigerators
Frezzer gets cold fridge dose not compressor and fan are running fridge only cools to about 46
Most modern combination units have two fans; one under the cabinet to move air over the coils and a second concealed behind the cabinets to distribute the cold air to both compartments. When you balance them to get the desired temperatures in each, you are adjusting the air flow from the cooling coils. Typically, the freezer has the coils and the fridge gets a little via ducts in the rear wall. If this fan fails, the freezer will suffer least and that seems to be what you are experiencing.
When the compressor is running, check the inlets in the back of the refrigerator to see if you have noticeable air flow. If not, that fan has failed.
Nov 29, 2009 | GE Refrigerators
My ge fridge model # gss20iemcc is only keeping crisper area cool
If you changed the defroster. you know how to take the top apart. Take the fan cover off there is a lover on the cover should be factory set but sometimes they come loose and stop the air from going to the bottom. while you there look to see if it has ice in it. If it dose. the drain may be stopped up.
Ken
Sep 23, 2009 | GE Refrigerators
My Ge profile with freezer on the bottom is not cooling. The fridge is 60 f or 15 C. The coils are clean and frost free. There is some frost on the copper tube that is surrounded by a foam wrap where it...
It is froze up there is no cool air going to the bottom. sometimes one will do that. defrost timer did not work. or the heat coil is bad. unplug it for about 8 hours to let it throw. and see if that will fix it. If it runs ok for about 5 days and dose it again. it is not defrosting.
Sep 22, 2009 | GE Refrigerators
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
275 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
