Question about Kyocera COPYSTAR CS-2050 Printer
Error code c6000 of copystar cs1815 - Kyocera COPYSTAR CS-2050 Printer
  • 200 Answers
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Posted on Mar 25, 2011
2 Suggested Answers
  • 126 Answers
SOURCE: copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Posted on Jan 16, 2009
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
Kyocera c6000 error
Fuser error try to reset it otherwise if it didnot work, change fuser unit
Nov 26, 2013 | Copystar Kyocera Taskalfa 181 Copier
Driver needed for kyocera cs1815
Try this location:
http://www.driverstart.com/start318276.html
Jul 11, 2010 | Kyocera Copystar CS-1820 Black and White...
What do you mean by error c6000 in KM4050?
Error code c-6000 means fuser error. It would be best to replace the fuser unit as a complete assembly, but sometimes just the thermostat can be replaced, which would be cheaper. Either way, an authorized Kyocera dealer should have these parts.
Nov 12, 2009 | Kyocera Copystar CS-1820 Black and White...
I have a copystar c2520 and am getting a c6000 error which was cleared with 10871087 and then 163 but now im getting a c6030 code and it will not clear. could this be that the fuser is no good?
C6000, С6030 is Abnormally high temperature in the fixing section – The fixing unit thermistor output voltage remains less than 0.5 V for longer than 1 s, indicating the fixing temperature rises above 536F this may be the fuser is no good. Sorry? coll to Servise center Mita. Dood lack!
Sep 22, 2009 | Copystar Office Equipment & Supplies
Hello
C6000 is the code for a heat unit error. Either a lamp is defective, or a thermal fuse blown or maybe a thermistor (heat sensing device) is dirty or bad.
Jun 24, 2009 | Kyocera Copystar CS-1635 Copier
C6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
press enter
press enter
select execute
press enter
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar cs1815 c6000 code
press enter
press enter
select execute
press enter
Aug 18, 2008 | Copystar CS-1815 Printer
Kyocera COPYSTAR CS-2050 Printer Logo
528 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
