Question about Kodak EASYSHARE Plus Series 3 Thermal Photo Printer
Our kodak esp 3250 insists there is paper jammed. An error box requesting we remove the back panel and take out the paper keeps coming up. We have done that. There is nothing there. We have rebooted and have made sure the back panel is on correctly.
  • 8 Answers
SOURCE: kodak esp 7 has a
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
  • 8 Answers
SOURCE: i have Kodak esp 5 all in one- says I have paper
f you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
backward.
SOURCE: Paper jam in a Kodak ESP- Printer
Right here we go. As already said above somewhere, slide the ink cartridges to the right, with a torch look into the left hand side where they had been sat. If you can see a pad there which when pushed it springs up and down ( and you get a black inky finger) push a plastic lug type lever at the back of this pad towards the back of the printer and the pad will slide backwards to reveal two squeegee rubbers stuck up. that is now the cleaning head unjammed. shut the top press ok and away you go, Simples.
Posted on May 27, 2010
  • 35 Answers
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Posted on Jul 26, 2010
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
Joed911
  • 4338 Answers
SOURCE: Kodak esp 3250 printer error.
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 29, 2011
How do you replce paper jam dor onkodak esp3250
Click on the link below to download the Kodak ESP 3250 user manual, inside this manual will explain how to reinstall the back panel
http://www.retrevo.com/support/Kodak-ESP-3250-Multifunction-Printers-manual/id/23553bh846/t/2/
Sep 07, 2014 | Office Equipment & Supplies
I have a Kodak ESP 3250. The printer keeps saying there is a paper jam. I have removed all paper I can see. If there is a small piece of paper in it I can't see it. Is there anyway to get to it to...
If everything is ok and printer is not printing it needs to be checked manually now. If you wish you can contact me at +1631-855-3940
or through IMO app +918510879267
Feb 17, 2018 | Kodak Esp 3250 Allinone Multifunction ( ...
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
I can't unjam the paper on my kodak printer
Just pull it slowly while pressing the button on the printer.
Oct 20, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
There is a paper jam in my printer and i have removed to rear cover but there was no paper that was jammed.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i try to print with my esp 3250 it says error: paper jam remove rear access cover. clear all paper. attach cover. press OK to continue.. but it doesnt work???
on the back there is a gray cover on the back right side there is a tab u push in and pull it out but mine is doing the samething and there is no paper in it
Jun 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
79 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
