Question about Sport & Outdoor - Others
How to use Aube # Tl033 Digital Timer - Sport & Outdoor - Others
Contents of the manual for Aube T1033 timer is longer than space allowed for free answer.
Open following link to identify timer and download manual:
http://waterheatertimer.org/Aube-timers.html
Aube T1033 timer is 7-day (no astronomic dawn-dusk feature)
Timer replaces single pole switch only and cannot be used for 3-way.
Heavy duty up to 2400Watts.
Controls halogen, incandescent, electronic ballast, and CFLs.
Timer is direct-wired into wall.
Timer does not require neutral wire since it has internal rechargeable battery.
Battery is not replaceable, and timer cannot be exposed to freezing temperatures because of battery operation.
If you have difficulty with wiring or programming: Add a comment with specific question about contents of manual for more free help. For wiring, add a comment and say what wires were on old switch.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 23, 2011
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
I need the manual to program my timer. I can't even get it to turn on.I did not get one with the timer
If following information is not correct, then add a comment with in-focus photo of timer buttons posted on flickr for possible identification.
Mr Steam digital timers are reportedly the Aube 7-day timer:
Aug 21, 2011 | Mr Steam 103588DIG Digital Timer in...
It just blinks on/off no matter how i program it and manual mode does not allow me to turn on. everything was fine until i switched to daylight savings time
You posted under Aube timers.
Resourceful do-it-yourselfer would include brand and model number for ease of identification and best possible free answer.
Open following link to identify timer and access on-line manual
Most digital programmable timers say 'reset' if timer stops functioning as expected.
Aube reset button can be pushed using paper clip. Usually hold-in button for 3-4 seconds.
Other timer brands and models use different method for reset, including holding down on-off button while reset is pushed.
If timer will not re-program or function correctly after reset, then timer is probably defective.
Aube timers have internal rechargeable battery that is not replaceable.
Most in-wall and plug-in timers have 1 year limited warranty. If Aube timer was exposed to cold temperatures, then warranty is probably voided since cold temperatures adversely affect battery life.
Add a comment for more free help.
Mar 17, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
Have an aube digital timer (7-day, model TI032) running outside lights. Just installed yesterday, when it comes on (either manually or on auto) I can hear a loud, audible clicking at a pretty fast rate...
Please review the technical manual for your Aube timer and check your wiring. I'm sure it is a oversight in the wiring.
I hope this helps you solve your problem...Please leave a comment...Thanks! Jim
http://www.aubetech.com/manuel/2/TI032.pdf
Feb 13, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
Is it possible to connect a digital timer(4 wires) to lite fixture with two switches? The switch I am trying to connect to is three pole and a ground
If I understand correctly, your switch has 3 poles, which makes it a 3-way switch.
You confirm this by saying light fixture has two switches.
There are two brands of in-wall timers that will work in 3-way situation. Intermatic and Aube. But only specific models of these timers work for 3-way.
The Intermatic EJ500 and ST01C battery-operated timers can work with 3-way switch. But wiring is tricky to impossible in some cases without extra wiring.
http://waterheatertimer.org/ST01C-program.html#ST01C
The easiest timer to wire for 3-way switch is Aube model T1032 which is a 500 watt timer.
T1032 manual:
http://waterheatertimer.org/Aube-T1032-timer.pdf
Look at the wiring diagrams carefully.
Note that you are replacing one switch with the timer.
The second switch needs additional jumper wire added to circuit between dark-colored screw and the brass-colored screw that connects back to #1 wire from the timer.
Add a comment if you have this timer, or buy this timer, and need help with wiring.
Dec 06, 2010 | RTO Intermatic Digital 7 Day Wall Switch...
The timer no longer working. I can only turn it on and off. It's a model that does not required voltage to work.
You posted under Aube in-wall timer.
If this is not your timer, add a comment.
Aube timers have a rechargeable battery that runs timer functions, and timer does not require 120 volts from circuit.
OK, I wrote to Aube about low temperatures affecting their battery.
Aube said, the battery is good down to freezing, and probably lower.
Lower temperatures cause display to slow down and not function, which means timer programs will not work when timer is exposed to cold temperatures.
Manual override would still work, but not programming or display.
So if timer is NOT located inside warm house, for example timer located in unheated garage or shed, then timer will not function in cold temperatures.
That being said, Aube battery is rechargeable.
Battery is not replaceable.
If Aube battery has gone bad, then timer is not repairable.
Intermatic ST01C and EJ500 in-wall timers are also battery operated. Intermatic ST01C and EJ500 battery can be replaced.
Almost all plug-in type timers also have a rechargeable battery that is not replaceable.
Several in-wall timers do not require a battery, but they need power from electric circuit.
To see these timers, plus description how to wire this type of timer:
http://waterheatertimer.org/Programmable.html#Aube
Nov 17, 2010 | Aube Technologies Aube 7-Day Programmable...
Lost power and need to reset the timer.
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
If you have different timer, add a comment
Nov 15, 2010 | Aube Technologies Aube 7-Day Programmable...
Will your timer work inside a cold garage though the winter?
Fixya doesn't make timers.
Honeywell makes the Aube Timer
Aube timers are a new product with a rechargeable battery.
Batteries are susceptible to cold temperatures just as you suspect
http://www.aubetech.com/products/produitsDetails.php?noProduit=75&noLangue=2
Aube/Honeywell has a 'contact us' page
http://www.aubetech.com/contactUs/index.php
I sent an e-mail to Aube tech support about your question.
As soon as they answer, I will post their answer on this thread.
I also posted a page on Aube timers with links and manuals:
Nov 10, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Lost the instructions T1032-33-34-35 can we get them?
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
Oct 06, 2010 | Aube Technologies Aube 7-Day Programmable...
Need instructions for Aube by Honeywell 7-day programmable timer switch
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
Nov 04, 2009 | Aube Technologies Aube 7-Day Programmable...
Sport & Outdoor - Others Logo
243 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
