Question about GE Washing Machines
AGITATOR WON'T WORK BELT IS TIGHT AGITATOR WIL TURN FREELY BY HAND
    Problem Solver:
  • 19 Answers
The agitator is controlled by the motor. If the belt is tight and the unit operates with power, then the motor must not be operating. ensure that it is receiving power and generating physical motion.
Posted on Mar 20, 2011
I have a whirlpool cabrio washer and the belt has came off during a washing cycle. I have tipped the washer over to check to see what was wrong and the belt came off. The cover has cuts in it where th
rarity but belt could be stretched does the big pulley turn freely is it tight is the motor tight if everything is tight and spins freely try a new belt
Feb 12, 2015 | Whirlpool Washing Machines
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Agitator spins freely as if not connected
Check to see of bolt is tight that holds agitator in place
Oct 02, 2009 | General Electric WHDSR209DWW Top Load...
GE model number wdsr2080daww, machine will not agitate. How do you remove agitator?
You should be able to just grab the agitator and hank it straight up and off. Sometimes you might have to slip a belt or rope under the agitator and fasten the rope to a 2x4 or similar and then hank up on the board. Remove the plastic part under where the agitator was (one 1/2 inch head bolt) . If it does not come off, break it off with a chisel. If the metal spline shaft under that turns freely by hand, you have a bad transmission. If it does not turn by hand, just install a new WH49X10042 air bell (agitator drive) and replace the agitator.
Mar 08, 2009 | GE WBSE2090A Top Load Washer
Washing Machines Logo
26 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
