Question about LG Dryers
Dlg3744w not getting hot - LG Dryers
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
The motor runs, but it does not dry all of a sudden. The dryer is mounter on top of the washing machine - seemed to be ******* via a mount together. Any suggestions?
First you need a volt meter and know how to read resistance and volts. Cause several things could be cause this. You may have a bad limit switch that blows when the temp gets over 160 degrees. The thermostat operates the heat to to around 155 degrees and shuts off flame or heat elements. It restarts at 135 degrees or so. Now if this part (thermostat) fails then the limit switch cuts the circuit. This could indicate your machine has a lot of built up lint and of course there is another limit switch to watch for this condition as well. I keep kits on my truck to cover all of these conditions. As you can see it's a little complicated but doable.
Mar 08, 2016 | LG DLG3744W Gas Dryer with 7.3 cu. ft....
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
My lg gas dryer model no dlg3744w will not heat
There are three high limit thermostats. Check all three for continuity. They should read closed (0 ohms). Check the flame sensor. They're cheap so you could just replace. It needs to close before the first solenoid opens and then open before the second solenoid opens. Again, easier to replace. Check continuity on the solenoid coils. They should read 1.5 K ohms. I replaced two gas valves before I recognized a "new" gas valve might not be really new.
May 04, 2014 | LG Home Applaince LG DLG3744W 7.3 Cu. Ft....
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
Car radio gets hot
There is a lot of heat generated and not a lot of ventilation so the answer to your question is yes, they all get hot. Now the question is what is too hot? Certainly we don't want it so hot as to roast marshmallows on or to melt anything or even WITHOUT TOUCHING IT too hot to touch. If it truly gets that hot there may be some trouble with the speaker or power wiring that is making it work too hard.
Feb 27, 2009 | Car Audio & Video
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
119 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
