Question about Honeywell Heating & Cooling
Have just fitted a replacement Honeywell powerhead for Honeywell V4073A 3 -way valve at my daughter's house. On fitting the mechanism seemed to be jammed and the lever to lock in the mid-position appeared to have no effect and was free to move up and down. After fitting all seems to work correctly except the motor casing inside the powerhead is very hot to the touch, even when the system has been shut down for some time. I have similar system on my CH system and the motor casing is not hot at all when system is shut down. Do you think there is fault in powerhead?
2 Suggested Answers
meBNme
  • 334 Answers
SOURCE: Central haeting ok but no hot water
If the valve runs at other times, the valve is OK. you have a relay somewhere that is not sending signal to the valve when in that mode.
Trace down all the relays for that cycle and check voltage going int, coming out, and to see if the coil is enrgised.
Posted on Jan 01, 2009
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
How to fit TVR to rear entry radiator which has supply from wall behind.
It can b installed i n the horizontal fit a 90 bend to fitting and connect up in to pipe work at the top of rad then bottom entry return
Sep 27, 2013 | Honeywell V2040DSL20 Straight Pattern 3/4...
Honeywell CT3600 does not turn off heat
Its hard to say where its getting power from. It should be a normally closed two wire valve, so power must be fed from the tstat only? Not real sure how it's wired. You could try a round of MUSICAL THERMOSTATS? That would answer your question as long as its played properly.
Mar 25, 2017 | Honeywell CT3600 7 Day Electronic...
Is the Honeywell TRV with numbers upside down(7 years old) can it be fitted on either flow or return?
not always if fitted on return they chatter all over the house need a model number to tell
Mar 16, 2012 | Heating & Cooling
I have honeywell v4073a 22 m valve on my central heating and need to get the head off as the valve appears to be sticking and is not sending hot water to the radiators. How do I remove it to check if it...
If you remove the cover of the valve ,you should see some screws that hold the motor head to the valve. you can loosen these screw and the head will come off of the valve body without leaking fluid. you then can try to pivot the valve stem and see if it is sticking or if the the valve motor needs to be replaced. reverse process to install. hope this helps.
Dec 21, 2010 | Heating & Cooling
Satchwell cylinderstat has brown, blue and earth (green/yellow) wires. which is te common and which is connected to the orange on a Honeywell V4073A 3 port valve. I presume the green yellow goes to the...
The colour codes are as follows:
Brown = Line / Active
Blue = Return / Neutral
Green/Yellow = Earth / Ground
It is likely that the Brown and Orange would be connected together but not 100% sure.
Sep 21, 2010 | Plumbing
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
No Water flow thru Humidifier
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Nov 22, 2008 | Honeywell HE365 Humidifier
Parking position
I think it only works on the advertisements.
Nov 26, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Heating & Cooling Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
