Question about Ranger TR-966 CB Radio
My tr966 has talkback hooked up on it and would like to disconnect it on the board?
  • 3,018 Answers
Your gonna look in your radio by the transformer for a"d25" diode 25 is what is removed in this radio to add talkback. If you want to disable talkback you need to replace that diode as this radio is not stock with talkback. Someone removed that diode. Diodes only go in one way. Pay attention to the cathode marking on the board and on the diode ( --> ) no smaller than a 1N914 diode as a replacement.
Posted on Mar 20, 2011
How to turn off talk back setting
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
See link below
https://support.google.com/accessibility/android/answer/6007123?hl=en
Jan 16, 2017 | HOW Video Game Consoles & Games
How to get talkback turned off
Hi Michele
Feb 29, 2016 | Cell Phones
Install a utb-1 talkback board in a uniden pc 78 xl+
why,just jump the pa and ext speaker outputs and you have instant talkback.
Feb 25, 2015 | Uniden Radio Communications
My galaxy dx 88 hl works great but the talk back won't work on am but does work on pa what is wrong
if you hooked it up its wrong but I assume you didn't.First of all talkback is a feature that allows you to hear your voiceand you don't5 need a radio check because you can tell by your own voice how your radio sounds if you want it to work on am you need to attach a 33ohm resistor from the positive to the neg of the external and pa plug ins. the talkback will be on all the time by the way.
Sep 27, 2013 | Galaxy Radios DX- 88HL Base CB Radio
How do I disable talkback on my cobra 29 ltd radio
check to see if its hook to the speaker jack. if it is just clip the resister. if its hooked to a dial then you are in hot water. follow the wires from those variables to see where they go . when you find the right one clip it.,no more talk back.
Jan 13, 2013 | Cobra 29 LTD CHR CB Radio Chrome Special...
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
I'm doing a talkback mod on a Cobra 29 LTD. I'm trying to wire it to the on/off channel 9, and I keep getting it turning onn all the time. When the switch is on or off, the talkback is still coming...
If you look at the tabs on the switch. You will have what looks like this.
hook one wire to the center tab of one side. And then hook it to the top tab of the same side.
Hope that helps.
Jan 26, 2010 | Cobra 29 LTD CB Radio
Disable talkback
one turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
May 31, 2009 | Connex 3300 240-Channels Base CB Radio
Scematic
Hi there!!
If you have an echo board what kind is it? I can give you the connections and where they go it just depends on which echo board you have!! I can also tell you where that talkback goes!! Let me know
Dennis
Dec 10, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
159 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
perdue40
TekkiDave
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
