Question about Nokia 6500 Slide Cellular Phone
Battery is not charging and phone is coming on.
    Sergeant:
  • 194 Answers
TRY RESETTING THE PHONE
Posted on Mar 20, 2011
Nokia 6500 slide charging pro
Posted on May 05, 2011
Tip
How to maintain Battery on our mobile phone for long lasting performance?
How to maintain our mobile phone battery for long term usage?
Many phone users never knew if how long the battery will last. As long as we use it regularly for a day or two,they are satisfied indeed.
Some problems.
* Other phone users preferred to buy mid or low quality batteries cause it is affordable,but the consequences,battery easily drained and immediately turns into low battery level.this can also damage the phone when the voltage is no longer at ease and the phone comes out with a short circuit board.
* Making a call,playing games,listening to music etc. while the phone is on charging.
When we got low battery warning,suddenly we plug the charger to the phone immediately cause we're expecting incoming calls,we might lose the momentum of the game or save the game level if suddenly the phone turns off. The result, phone is getting hot and the battery is deform due to simultaneous current entering the phone.A voltage coming from the battery and a voltage coming from the charger. also may lead into a short circuit problem and affects some parts of the mobile components.
* Overnight charging or charging the phone for a long time.
This might happens when we're using the phone until we almost got asleep at night while the mobile is on charged. Exceeding the voltage requirement of a battery as well as the phone itself may lead into battery discharge,deform structure and also causes short circuit problem.
Tips
1. Buy original battery coming from an authorized retail outlets and ask for a warranty for security purpose. Look for the quality seal product to assure that you've got the right product.
2. Follow the manual on the charging procedure when you bought a new battery. Observe the initial charging time and the regular charging time.
3. Never use your phone while on charged. (if it's important, you can do it sometimes but not regularly) make sure the phone is turn off and observe the regular charging time.
Hoping that this simple guide of mine helps.... Good Day!!!
on Jun 23, 2011 | Cell Phones
I have a Sony experia ce0682, the red light comes on when I'm charging it but it will not turn on??? Help.
The first that comes to mind is your battery. When charging your battery, do you also play games on your phone the same time your phone is charging? If so, then you can overheat your battery which could significantly drain your battery life and could really damage the battery. Also, has the battery been in contact with any liquids? And lastly, check the battery. If you take out the battery, and lay it on a flat surface, spin it. If your battery spins like a top, you need a new battery.If the battery is bad, it does not hold a charge to power the phone from its stored energy. However, if the phone functions properly, the phone may still power up when a power source is connected, and utilizes that power. If the phone does not power up after it has had time to charge thoroughly, it is more than likely time to get a new battery.
Aug 04, 2014 | Cell Phones
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 | Cell Phones
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
Phone wont come on
your phone may be charging, but is your battery taking any charge? it seems that your battery is dead. try a diferent battery in the phone or check this battery elsewhere. you can even touch both the terminals to your tongue and see if there is a tingling feeling. Do not worry, 3.5 volts and 860 mAH have never killed anyone. if the battery is the culprit, change it. if the battery is holding charge, then the problem is withthe poweron switch or elsewhere. have it checked by Nokia Care.
Sep 03, 2009 | Nokia 6300 Cellular Phone
If my sidekick is refurbished and it charges but dont come on what can i do?
the Sidekick 3 has a charging issue that cropsup after awhile. The charge port gets broken and It will just not charge the battery. A good way to tellis if the orange light comes on but the phone never charges.
If you have a friend that has a sidekick 3 or sidekick ID, try their battery in your phone to see if it powers up.
Youcan get an external battery charger for the sidekick for about 25dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
SPV C500 Charging problem
If you mean the amber 'charging' light does not light when charging, note your PC must have a working Microsoft ActiveSync installed on an XP, Mobile Device Manager on a Vista PC, before the phone will charge from a PC USB port.
If it will also not come on when the AC charger is connected, then I would suspect a bad light or what ever supplies the light.
How do you know it is not chargeing if the phone comes on. Are you saying the phone will only come on when plugged in a PC or AC Charger? If so, I would suspect the battery. Unplug it and clean both the battery terminals on the battery those on the phone the battery mates with. You can use a clean pencil erasure.
Batteries are cheap on ebay.
Feb 11, 2009 | Orange SPV C500 Pocket PC
Phone not charging
Last time I went to charge mobile phone, it would not charge. Phone comes up with low battery. Would it be the charger or the battery or phone?
Oct 08, 2007 | Lands Phones
Nokia 6500 Slide Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
