This
is a clear evidence of a broken lid switch. Power to the drive motor is
routed through the lid switch during the drain/spin cycle. The machine,
therefore, cannot drain and spin when the lid switch is not working.
The drain pump doesn't work because it is directly coupled to the rear
spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the
console and lay it back on the hinges.
Disconnect the lid switch harness conneModel 110 purchased in late - 9698f29.jpgssing on the tab
located in the middle and pulling it up.
The cabinet is attached
to the rear of the washer by
two brass-colored
retaining clips. Insert a flat blade screwdriver into the turned-up edge
of thModel 110 purchased in late - 4e2277c.jpgated on both sides, and then pry back to release the
clip from the slot in the cabinet.
Open and hold the lid while grabbing
the cabinet front opening then tilt the top of the cabinet toward you by
pulling the cabinModel 110 purchased in late - 8557e5b.jpgm the base. This releases the front and
back slots of the cabinet from the tabs in the front and back of the
base.
Using the side of your leg and/or body as a support for tModel 110 purchased in late - 9652994.jpgof the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove
the lid switch Model 110 purchased in late - b27a7aa.jpgmounting screws then release the wire harness
from the metal retainers. Pull the lid switch connector out and install
the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the
base
of the machine then lay down the cabinet into position. Make sure the
slots in the cabinet sit into the tabs at the base of machine. Reconnect
the lid switch harness then push the retaining clips back down into position
to secure the cabinet to the rear of the machine. Reinstall and secure
the console to complete the repair.
Let us know if you need further advice but indicate the exact mode number of the machine. Please accept
the solution should you find it helpful or informative. Accepting the
solution will not stop you from communicating with the expert. You can
still communicate with the expert should you need further advice
regarding the issue stated herein.
