Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Front bristles will rotate for about 20 seconds and then automatically stop
2 Suggested Answers
  • 44 Answers
SOURCE: Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Posted on Sep 21, 2012
Dyson dc 50 issues
Have you tried replacing the rubber drive belt for the roller?
Jun 07, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
Front brissels dont rotate
have you removed the bristle bar to see if carpet fibers have wrapped around the ends causing the bar to bind up, have you noticed any smoke smell, if so your belt may have broken, easy way to check, flip the unit over and remove the bottom cover plate, whats wrong should be obvious at that point.
Dec 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hi we seem to have a problem with our Sebo .When in use as you draw the hoover back and forth seems to become very heavy to push as if the suction is becoming stronger. PLease can you advise. Mary
As you know, your Sebo automatically adjusts its brush height according to the type of floor it's on. At the correct brush height, on carpet, the machine should almost pull itself forwards. If this is not happening, the first thing to check is to look and see if the bristles on the brush roller are very worn (bristles on a new roller will almost entirely fill the available space). If they are worn, a new roller will almost certainly solve the problem. If the problem persists, the automatic height control mechanism may have failed (possible but very unusual) and a professional repair will be necessary. You may notice that I haven't even mentioned the possibility that one of the belts may have broken (in which case the brush roller will not be rotating at all) - because of the machine's excellent design, broken belts are almost unknown (they can last for 15 years and more) but not completely impossible.
My message in a nutshell: look to the brush roller first. If a new one doesn't solve the problem, go to a professional repairer.
I value your feedback, so please remember to rate my response.  Thanks!
Jul 17, 2009 | Sebo X4 Bagged Upright Vacuum
DCo7 too much suction hard to push
This suggests that the bristles on your brush roller are worn out.  When the bristles are a good working length, rotation of the roller actually helps to pull the machine over the carpet. When the bristles wear down this effect is lost.
May 20, 2009 | Dyson DC07 All Floors Bagless Upright...
Power brush motor seems too weak
This machine needs a new belt. The belt is stretched into position and even if it is not used, will fatigue over time. This can occur as the machine is in storage waiting to be sold. If you check the bristle on the roller, you will observe that it extends out the bottom of the powerhead quite far and is very stiff. This causes the brush to engage the carpet very aggressively and puts considerable strain on the belt. A tired belt will fail very quickly under these conditions. You should take it to a warranty depot and have the belt changed.
This machine also has variable speed motor in the main unit. This is so you can adjust how heavily the powerhead brushes the carpet. If it is set too high, on certain carpets, the suction will pull the powerhead down too hard and this will bogg the roller and cause the belt to fail prematurely.
Feb 02, 2008 | Hoover S3765-040 WindTunnel Bagless...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
118 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
