When turning on cool and fan auto a snowflake blinks. My fan does not blow. What does this mean?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
The snow flake blinking usually is an indicator of a delay to prevent short cycling of the condensing unit. Wait for the snow flake to stop blinking, then the unit should start running.
Posted on Jun 06, 2014
    Genius:
  • 1,157 Answers
Hi Markmywords5,
If the fan of your Air Conditioner does not blow, it might caused by bad fan motor or fan wire/switch may not be connected properly. There are several ways on how to check this issue, either you check if the fan motor is already burned out or just check to make sure that the breakers for the furnace/air handler and the air conditioner are on. Here are some steps that you may apply on this issue.
1. Check the breaker. If the breaker is tripped, please reset it by shutting it off and then turning it back on. If it's still tripped, you need to check the wiring in the furnace/air handler for signs of damage.
2. If the breaker is not tripped, then the problem may be your thermostat, the furnace/air handler control board, or the wires between the furnace/air handler and the thermostat.
3. Also please check the contractor. Contractor is a type of switch located in the outdoor unit. Please check if it is "pulled in". If it is pulled in and the motor doesn't spin, you need to replace the motor.
Please leave the power off until the unit is repaired.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 20, 2011
Luxpro heater thermostad
the snowflake means you are on cooling, blinking typically means a time delay.
Jan 03, 2018 | Heating & Cooling
Luxpro PSD111 thermostat reading 78 when set to cool at 72. Snowflake blinking and not cooling. Please advise. Thank you.
Usually blinking means you are in a time delay. Obviously not for three hours but... Turn fan to on position and verify your indoor fan is working. If so check outdoor unit and see if it's running. If no indoor fan turn breaker off, and inside the tstat put the red and green wires together and turn breaker back on. If indoor fan runs you have a bad tstat. Good luck!!
Mar 22, 2017 | Heating & Cooling
Air conditioning not working. Have White-Rodgers thermostat 1F79111, I think. Replaced batteries. Now have flashing signal like an asterisk. What does it mean?
Blinking snowflake means it's on time delay for cooling to come on (usually 5 minute time delay to prevent compressor short cycling). Solid snowflake means cooling is on
Aug 03, 2016 | White-Rodgers (Protech) White Rodgers...
Flashing snowflake
The flashing snowflake means it is in the cooling mode, but is waiting for itself to 'time out' after a call for cooling. It should be about a 5 minute delay then should come on automatically. At that poing, the flashing snowflake becomes steady.
Try it one more time and set the timer on your smart-phone to ten minutes before you touch it again. If that time elapses and no cooling and it is still flashing there's possibly a problem in the thermostat that will necissitate replacement.
Aug 02, 2014 | Honeywell Heating & Cooling
I have a digital Honeywell thermostat that has a blinking snowflake. When the thermostat is on auto mode it does not turn on. When I turn the thermostat to fan I can feel and hear the air blowing out of...
If the thermostat has a blinking snowflake then it is in time delay mode which sometime can take between 5 to 7 minutes before it will turn the AC and Fan On......Then it will go to a solid snowflake.
When you turned it to fan On it starts the Fan right away..... After the snow flake has went to solid check to see if the fan is running and then look outside to see if the Fan Blade is turning on the AC..... The fan blade comes on the same time as the compressor does. Then with the fan running hold your hand above the air stream above the AC and if you can noticeablely feel warm to hot air comeing out the Top then the compressor is running also. If the outside unit is not running I would check to make sure the Main Breakers are turned ON.... After the AC has ran for a few minutes feel the copper lines that go into the house the smaller line should feel warm to hot and the bigger lines with insulation on it should feel cool to cold and sweating with beads of moisture on it..... That is a quick test to see if the unit is working properly.....If you have a Thermentor and can Check the Temperature of the Return Air and the Supply Air .. You should have about 20 Degree F Between the Supply and Return........ 75* Return - 55* Supply would Equal 20* TD Across the Coil......
That is about all you can do to check on your own....... If the compressor is not coming on or the lines are not the temperature difference then you will need to get professional help for your Air Conditioning System..... Goood Luck Hope this Helps.........
May 14, 2011 | Heating & Cooling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
Are all symbols on a/c the same
Ok the snowflake means that the unit is cooling. The sun means that the unit is heating, the raindrop means that the unit is dehumidifying, the fan means that the unit is using the fan only as ventilation without cooling or heating and the funny triangle looking thing is auto mode where the unit sets the mode automatically. The little bar in the middle displays fan speed and the two little arrow things next to it means that the fan is in auto mode where it sets the speed automatically. There I hope that that helps.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 25, 2009 | Heating & Cooling
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
Flashing snowflake symbol and a/c is not blowing upstairs
flashing snowflake normally means it is in a time delay. give it five minutes and see if it continues.
Jul 20, 2009 | Honeywell Electronic Programmable...
Re: 1998 Mitsubishi Diamante Air Conditioner problem
check the refrigerant it might have 2 be recharged
Aug 18, 2008 | 2002 Mitsubishi Galant
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
