Question about Whirlpool Duet GHW9150P Front Load Washer
The seal around the door become intangled with the clother in the washer and ripped it off. There is a circular spring that i assume was holding the seal on. Could you tell how to put the seal and the spring back on.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Here is the complete repair manual for the Duet washer. Look on page 4-4 for information on the seal.
Posted on Mar 20, 2011
Loose rubber seal and a circular metal bit has come off it has a spring at the bottom
That is your door seal with a spring that goes all the way around it and has a screw that holds the spring tight together.
Jul 09, 2015 | Washing Machines
Just wondering can the rubber seal be changed on my Whirlpool duet front load washer? The seal around the tub of my machine has a small rip in it and now the water flows out when I am washing my clothes.
yes they can, the bellow seal is about $100 and take care when removing the outer tub spring and the front seal spring so you don't kink these or the new seal will leak around the edges
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
A piece of fabric got caught in the seal and it it slightly torn and the seal is warped. A round wire with a spring fell out and the door will not close.
you will have to replace the boot glove as this is what i think you mean,the part were the door fits into,if there is a rip in this rubber boot then water will leak through teribly,the round wire you refer to is the wire that goes around the boot to hold this securely to the washer preventing it from leaking,hope this helps,rgrds,paul
Jul 07, 2009 | Kenmore HE2 Plus Front Load Washer
How do I replace the door seal on my ZWF1421W washing machine
Unplug the machine first! Open the door and look around th edge of the seal. You will see a plastic clip, where the two ends engage (like crocodile teeth), prise it out toward you with a flatbladed screwdriver. Unpeel the seal frm around the door. Hold the top of the seal inside where it is attached to the drum and lift it slightly, then just pull it off. You will see it is held on with a big circular spring. Getting the new seal on is a pain. It must lip onto the plastic outer drum and will take patience to feed it on, not to say sore fingers! Once on, fold it intowards the drum and then you have to stretch the spring back onto the seal...more sore fingers. Maybe someone can hold it while you feed it aound (make sure also you have fitted the seal the right way up!). Finally, attach the outer lip onto the lip of the machine and reattach the outer plastic clip. Good luck!!!!!!!!
Feb 18, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber Seal not Sealing
This seems to be a common problem with front loaders, but there is an easy fix if you follow these simple steps:
1. The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first.
2. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions.
3. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this.
 Good luck and I hope this helps you.
Oct 24, 2007 | Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
285 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
