Question about Miele K855ID-1 Refrigerator
Its not very cold. i have lost the manuel is the dial the coldest on number 1 or a higher number
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
On my freezer is a dial that has 1 to 7 what is the coldest as it has been on three and is not freezing the meat it is a prestcold chest freezer
the higher the number the longer it runs and the colder it should get. try a higher number ok. later gator.
Mar 14, 2011 | Refrigerators
I have a dial control. Is 1 the coldest or the warmest.
One should be the warmest and just before off. When you turn the knob, listen for the sound of the compressor turning off or on. If it comes on when you are turning to the higher numbers then the higher the number the colder the freezer.
Aug 09, 2010 | GE FUF17SVRWW Upright Freezer
Temperature 1-3,1-c, coldest?
the higher the number and alphabet the colder it will be
Aug 18, 2009 | Frigidaire FRT17G4B Top Freezer...
Deciding which way to turn the dial to get the minimum temperature
Coldest when you are on the higher number or higher letter. Ave setting should be around 3 on a scale of 1 to 5.
Apr 12, 2009 | Refrigerators
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Miele K855ID-1 Refrigerator Logo
37 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
