Question about Sony PlayStation Portable (PSP) Console
I'm having a problem with my psp. It is not reading my umd games at all. The disc isn't even spinning but when I start up my psp the disc does spin but it is stuck on the start up screen and wont go to the menu selection. Also when I try to start an update or an eboot game it freezes and shuts down. Please help. And if it means anything my psp was dropped and it was after that I've been having problems.
    Problem Solver:
Hi there, can i ask? something what happen to my psp it can't play games or change cfw, when i want play games or change cfw it freeze at psp logo not loading and then switch off...what happen..but i still can play the music, video and online... picture also can..please help me
Posted on Jul 19, 2011
    Sergeant:
  • 194 Answers
May i know the frimware of your psp console
Posted on Mar 20, 2011
  • ghostxtiger Mar 20, 2011
    6.35 OFW that was modded to 6.35 PRO-B CFW. After it rebooted I tried to start the fast recovery provided and that's when the problems started.
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Help
Hi Bvogel987,
You probably need a new UMD drive. I have seen this many times. Try the following to restore the drive.
  1. Turn the PSP-1000 on,
  2. Open the UMD door
  3. Press down on the black peg poking up at 8 O-Clock in reference to the disc spindle.
  4. You should see the disc spin, and Laser light up. If either does not, then you need a new drive.
  5. If they do spin and light up, Take a toothpick, and wrap paper towel aorund the tip of the tooth pick,
  6. Dampen the toothpick swab with a Windex type cleaner.
  7. Swab the laser lens, and move the lens with you finger or toothpick to the right a couple of clicks. Place a new paper on the toothpick and dry the lens.
  8. Test. If this did not work, you still need a new Drive.
I run www.PlayStationClinic.com and we replace PSP-1000 UMD drive for $47.00 including return shipping and handling.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp
have you tried various disks? certan disks may either be scratched or dusty so you coul take a can of compressed air and ust out both some umd's and the umd tray of the psp. also, if you're usuing a custom firmware, you may find it will work once you revert to an official firmware
Jan 19, 2008 | Sony PlayStation Portable (PSP) Console
Problem Running Games - no UMD symbol on console
I THINK THE OPTICAL PICK UP OF UR GAME HAS BEEN FAILURE , JUST CHANGE IT FROM ANY NEAREST SERVICE CENTER
Jan 18, 2008 | Sony PlayStation Portable (PSP) Console
PSP DOES NOT READ DISCS/ UMD GAMES AND DVDS
HI Josh,
It sounds like your UMD is Shot man.  I have tried to help you. Do you think your skilled and patient enough to Disassemble the entire PSP to REpalce your UMD Drive? If so , Write me vback.
Oct 18, 2007 | Sony PlayStation Portable (PSP) Console
Menu of the psp
Try a different disk? I've found that sometimes when you turn on the psp and you're in the game menu of the PSP menu, the UMD won't be there, but if you go over to music or something, and go back to game, it will have returned.
Aug 09, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
264 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
