Question about Harman Kardon AVR 130 Receiver
When switching on the ampli, I get a message "amp
  • 604 Answers
You may have a shorted speaker wire. unhook all the speakers and test each speaker by using a 9 volt battery across the speaker wires, you should hear a pop (this will not hurt your speakers). in each speaker. if you don't hear the pop then you may have found the one that is shorted. Another thing you can try is to unhook all the speakers and trun on the system (briefly) and see if the message is gone, this being further indication that you have a shorted speaker wire.
Posted on Mar 20, 2011
My surround sound sony 7.2 ampli audio turns off when i turn it up
try checking if all the speaker cables are connected in polarity ( all + to + and all - to -
make sure that the speakers u have connected are not below the amplifier manufacturer specs and that that they all have the same OHM load (check back of speakers to see the (OHMs)
lastly, check each speaker individually to determine that they are all working and working with no distortion. ( a malfunctioning speaker could cause the amp to go into protection.
if there are any more details that you did not state please do so.
wish this helps
......andy......
Jan 02, 2014 | Rockford Fosgate Punch 601S Car Audio...
Is yamaha ampli rip off ?
I have not personnally had any problems with any yamaha recievers, or surround processors that I have ever purchased, and they continue to operate these decades later. The fact that they have pre-amp outputs for all channels was a major determining factor, as I could then use other amps with more power for expansion. make sure you have a surge protector for your ac power supply, that has been the biggest source of problems with any piece of a/v equipment
May 21, 2013 | Yamaha HTR-5660 Receiver
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
What does "This memory card is write-protected
On the SD card itself is a write protect switch - it's on the side. Check the switch to see if it's in the protect position.
Jan 25, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a PowerShot SD450 and have a "Card Locked!" message. What's up with that?
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Jan 16, 2011 | Cameras
When I turn on the player...the "PROTECT" message comes up... I would like to know how to start this player...or how to bypass this message so it pplays. Hope somebody out there knows the...
protect means that the speakers are improperly hooked up or just not compatible with the amp.
ensure that the speakers are 8-16 ohms, that no wires are crossed, and no wire strands are loose, which could touch and short. a 4 ohm speaker or a short in the wiring is almost always the cause of a protect error.
if all of this is checked, and it still says "protect" then it is fried.
Nov 06, 2010 | Sharp Audio Players & Recorders
WHEN I PUT MY JVC GR-D770U IN VIDEO MODE TO RECORD VIDEOS, AN ERROR MESSAGE IS DISPLAYED THAT SAYS, "CHECK TAPE PROTECTION TAB". HOW DO I TAKE CAMERA OFF PROTECTION MODE SO I CAN RECORD VIDEOS?
Mini-DV tapes have a small physical switch on them to protect the contents from being overwritten. It is probably just that this switch is set, not a problem with the camera.
Oct 31, 2010 | JVC GR-D850 Mini DV Camcorder
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
My ampli start bot only in protection mode
amp could be blown, i.e. speaker wires crossed up, too much power..............
Jun 07, 2009 | Rockwood X-Plore AMP-4010 Car Audio...
Harman Kardon AVR 130 Receiver Logo
54 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
