Question about Kenmore 22422 Top Load Washer
The agitator wont turn even by i cant turn it
    Problem Solver:
  • 19 Answers
"the agitator wont turn even by i cant turn it"
Do you wake up in the morning with the goal of butchering the English language or does it happen accidentally?
Posted on Mar 20, 2011
Model GW712av wont agitate
Will the bowl turn with no water in it,
If not turning the bearings are seized and rusted.
A bearing and seal kit is needed for your machine.
Aug 15, 2012 | Fisher and Paykel Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Washer agitator wont turn!
what do you mean wont turn, do you mean when it spins that agitator is stationary ? in that case you need a new transmission. if you mean that in a dual action agitator that you can spin the agitator top left and right with no resistance / the bottom doesnt move either, then you will need new agitator dogs. remove the top of the agitator and i mean the cap, some have fabric softner dispensers on the top, which means pull the green tab up and the dispenser will come off, then you remove the cap to the agitator. under that is the agitator cam. you either need a 11mm socket to take it off, or you will need a 1/2 in ratchet and extension to take it off. after that it should be very easy to replace the agitator dogs
Feb 07, 2011 | Washing Machines
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator cant be removed from base to get to clutch dog
hi, There is a 7/16" bolt that hold the agitator in. Remove the top cap on the agitator and the cap inside it to get to the bolt. Once you get the bolt out, pull the agitator out and seperate the two pieces.
I hope this help you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top of the agitator just lifts up and is not secure to the post.
Hi Tom,
Glue! hehe...Nope, there's a bolt in there. I think it'll take a 7/16" socket.
SG
Mar 27, 2009 | Maytag SAV4655A Top Load Washer
Spins, drains, wont agitate
There could be a problem with the transmission/gearbox (but that would probably involve you hearing some load noise's). It could be that the timer just needs to be replaced,,, or its even possible that since taping the timer makes it work sometimes that there could be an electrical problem between the timer and the transmission/gearbox, liek maybe a rusted or lose wire.
Mar 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE washer approx8 yrs old
Slip a belt or rope under the agitator and attach both ends to a thick handle, rod, or pipe. Yank up hard. Agitator should come right off. Remove the plastic upside down can shaped agitator drive spline, which is held on by one bolt. It should come right off, but sometimes you have to crack the plastic to remove them. If you cannot turn the small grooved metal shaft (that you can now see) with your fingers that's good, you can just replace the agitator drive with a new one, replace the agitator, and you are set to go. If you can turn the metal grooved shaft with your fingers, you are basically screwed, as you would need to replace the transmission. (which is not really cost effective on your out of warranty low end washer)
Oct 30, 2008 | GE WVSR1060A Top Load Washer
Kenmore 22422 Top Load Washer Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
