Question about Zenith Audio Players & Recorders
Zenith cv 5000
Need hookup diagram
Need user manual for a zenith tt cv 660
This model is a rebranded JVC L-E50B The JVC manuals may be easier to find (reference: last post in AudioKarma org Home Audio Stereo Discussion Forums quick tour Zenith CV...
You might be able to get a manual for the JVC at
http://www.vinylengine.com/ but you have to register and I didn't.
26.May.2015
May 26, 2015 | Zenith Televison & Video
Picture freezes on zenith z50pv220 w/satilite hookup
Hello
Picture freezing is related the faults with its digital processing board. It is a very skilled work, as you need O'Scope and all other testing equipments, and a though knoledge in electronics to do this work. It will be best to get this set repaired by its authorised service center.
Feb 12, 2012 | Zenith Televison & Video
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Vcr hookup
Try using a S-Video cable if your VCR has the connection. Otherwise, use a RCA composite-video cable on one of the AV inputs of the TV. The cable has a Yellow, Red, White color, the same as the jacks it goes in.
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
I beleieve all the hookups are correct. I'm timer
Make sure the scart leads are fully in both on the vcr and tv,if they are not this can lead to no pic but sound or sound no pic
Oct 08, 2009 | Panasonic Televison & Video
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
Zenith A25B33W changes channel sporadically
sounds like the little button switches are leakey they are mounted to the board and are very small may need to replace them. They are right behind where you push the power on channl up down and so on buttons on the set.
Mar 09, 2009 | Zenith A25B33W 25" TV
Z20LA7R Zenith Telivision VGA Hookup Problems
Watch my video and I explain the problem you're having with the VGA/PC input.
Jan 10, 2009 | Zenith Z20LA7R 20 in. EDTV-Ready LCD...
212 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
