Question about HP Photosmart C6180 All-In-One InkJet Printer
I just replaced the ink cartridges,but it still says that the blue one is empty,and doesn't let me print.help
    Problem Solver:
  • 17 Answers
If you replace the cartridge with a new one and the printer still says it is empty, then most likely you didn't install it properly. Remember you need to shake the cartridge before your install it.
Posted on Mar 20, 2011
    Sergeant:
  • 194 Answers
Try resetting the printer and try it again
  • Majesty_po Sep 11, 2011
    How do i reset my printer?
The color of my print is very pink and yellow with no blue
If your printer has 3 colored ink cartridges, your cyan (blue) cartridge is empty. Replace it with a new one. If your printer has just one colored ink cartridge, the blue section of it is empty. Replace the cartridge with a new one. You'll find the correct cartridge (normally a number) in the owners manual and/or on the cartridge itself. See the owners manual for instructions on where the cartridges are located and how to replace them.
Oct 12, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hp 8500A won't print if one ink cartridge needs to be replaced
Its simply because the cartridge is not making a good contact with its socket.
1-switch off the printer and totally unplug it 2-clean the cartridge properly
3- check the cartridge clip
4-return cartridge and send a feedback to us
Jul 09, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Photo prints
Try cleaning mode on the printer, secondly a single color on a print or two or thre with one color noticeably absent means that that cfartridge is close on or is empty. EG Red Blue Yellow most of print is Ok but at end of print only blue seen means RED AND yellow are empty and only blue has some ink left. Replace ALL cartridges so your prints and paper arent wasted .
Jul 27, 2009 | Computers & Internet
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Blue ink - printing problem
Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge!
Good luck.
Sep 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
