Question about Amana Refrigerators
Owners manal for amana refrigerators - Amana Refrigerators
Does my Amana refrigerator model number SBD20S4E have a water filter, and if so where is it located?
THis is a great question to go to the owner's manual for but I believe yours is a side by side. SOme filters are low behind the grill, others are inside:
Here you go Amy:
Jan 11, 2015 | Amana Refrigerators
How much space is needed between the refrigerator and cabinets, top and sides?
Down to zero on the sides ... 4 iches in the back ... couple inches at the top ... unless Amana tells yo something different in the owners manual ... http://www.amana.com/
Thanks for your visit today.
Feb 02, 2011 | Amana ASD2626HE Side by Side Refrigerator
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
Refrigerator not cooling, at last check 55 degrees, freezer working fine, can not find owners manual help
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
j
Sep 27, 2010 | Amana ABB2227DE Bottom Freezer...
Amana Refrigerator stopped functioning.
no way!!!!! do not try to cut into the cabinet. the wires inside the cabinet will "never" fail. this "so called" repairman is wrong and needs to be sent away.
too bad you paid him to check this out but if its a company and not just a single owner then ask them for another opinion. for "free" then when they find out you have a bad main control board it will end up costing you about 300-400 bucks for a replacement.
what you need to do is call amana and ask them to see if they will recommend an authorized company give you a second opinion.
then ask if they will help with the cost of repairs. most of the time they will give you a concession for repairs.
a 2 year old unit is too new to have a major repair.
good luck with amana, as they are now owned by whirlpool, but you do have a good chance to get a free repair.
Jan 21, 2009 | Amana Refrigerators
Amana bottom freezer refrigerator stopped working.
Check and clean the condenser coil in back under fiber cover and make sure you reinstall the fiber cover as it is necessary for proper air circulation . (IF) your system needs refrigerant, which I doubt, it would be a sign to get a new one.
May 15, 2008 | Amana Refrigerators
Refrigerators Logo
67 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
