Question about Dryers
I used my dryer 5 times and on the 6th it just quit. Now nothing. The light went out and it won't turn on at all and the timer doesn't work either. But before that all was fine.
  • Dryers Master
  • 8,220 Answers
I first check for blockages that would make the dryer overheat and remove themI used my dryer 5 - themobilian_1986.jpgthemobilian_1988.jpgthemobilian_1989.jpg
After removing the clogs I go ahead and find the duct fuse.
This is a non resetable fuse which kills power to the dryer when it overheats.
ExampI used my dryer 5 - themobilian_1990.jpgttp://i.fixya.net/uploads/images/themobilian_1990.jpg" alt="themobilI used my dryer 5 - themobilian_1991.jpg"h_mi" />themobilian_1992.jpgthemobilian_1993.jpgthemobilian_1995.jpgService manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 20, 2011
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Dryer has quit heating
Sounds like the heat coil has went bad you can pick one up at a appliance store,but the cost would be close to buying a used dryer,also check and see if something has gotten on the coil and shorted it out I had a dyer one time that I found a little dead snake on it,I removed it and it work for many years good luck....
Jan 10, 2013 | Dryers
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Electricial problems wrong voltage used . have a kenmore dryer, sent dryer to europe and was connected to two circuit like in the US but the voltage in europe is 1 curcuit 240 volts and 2 circuit 400...
The dryer has sone things inside that require 110 volts. Specifically the motor and the timer. Therefore if by some chance that you haven't yet damaged anything, it still will not run until you have a 220 volt center tapped transformer to similate US power (220 volts with a neutral). Also, since the foreign power is 50 Hertz, the timer will run slow (5/6th speed) as will the motor. And the motor, being designed for 60 Hertz, will run unusually warm.
Nov 29, 2009 | Kenmore Dryers
Dryer wont start
Your motor is bad.
Apr 19, 2009 | Dryers
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Kelvinator ED 56 Dryer
reach inside and see if the drum turns real easy. It should turn real easy even wth wet clothes in it. if it hard to turn then the motor aint gonna get going gonna run hot and quit.
Jun 27, 2017 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
Marvin
Marvin
