Question about Hayden Industries Vacuums
Hayden 3600 the motor is pulsing off and on at about 1 second intervals
3 Suggested Answers
  • 25 Answers
SOURCE: Hayden Premier Motor Pulses
there are several possibilities here, its possible the low voltage relay is bad, possible that the carbons on your motor are worn, or may even be a thermal sensor in your unit shutting it down, ive even seen improper assembly of motor which cause wires to be pinched and have shorts in them from the manufacture, course always check your power cord to the wall and test your outlet with some other appliance.as you can see several possiblities, most of which unless your knowledgeable in electricity i wound not atttempt on my own. highley reccomend taking to a vacuum cleaner shop to have checked out at least, they may even be able to sell you the part to fix it yourself
Posted on Mar 27, 2008
SOURCE: Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 22, 2008
Hayden product. how to disassemble the head to replace the belt.
Actually Hayden's power nozzle is manufacturered by Panasonic for Hayden. Panasonic is the same maker of Kenmore vacuums as well. I have written a detailed repair solution on how to replace the belt on a Kenmore Canister vacuum, and the repair on your power nozzle will be identical.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
The only difference could be that you may have a newer style power nozzle then this one, and the screws on the newer nozzles are actually on the bottom of the power nozzle rather then underneath of the headlights.
Hope this helped you,
Chris J.
GoVacuum
Apr 10, 2010 | Hayden Industries SuperVac 3600 Central...
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Mar 24, 2008 | Hayden Industries SuperVac 6000 Central...
Hayden Vac2400
Check the carbon brushes, they maybe worn out and need replacing.
Jan 06, 2008 | Hayden Industries SuperVac 2400 Central...
Vacuums Logo
60 people viewed this question
Top Hayden Industries Vacuums Experts
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
