Question about Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Problem with the Sharp LC-26DV24U 26 in. HDTV LCD TV TV/DVD Combo LC-26DV24U. Sound OK, White screen. Replaced...Ads by GooglePower Supply Repair www.PowerClinicInc.comProfessional, cost-conscious repair Most makes and models - since 1987 By macafly on Mar 05, 2011 LC-26DV24U. Sound OK, White screen. Replaced Q413. No Joy. 12.8v on E, 1.55v on C, and 1.38v on B. 1.38v and 0.09v on either side of R518. 3.33v on 13 of cp401. Know just enough to be dangerous, but always willing to try and curious how thing work. If I short emitter/collector on Q413 I get picture, but I'm sure there is a reason for the circut. What's next? macafly14 days ago nothing obvious with the caps. pg e-3 says to check pins 1-5 for 5 v on cp2804. I've searched high and low and cannot find cp2804. at cp2802 pins 1-4 show 1.55v and pin 5 0.00v. Another note, This is the later "A" unit, and I have both service manuals. The "A" manual schematic shows 12v for pins 1-4. I don't understand the circuits, but it seems Q419 controls Q413 and J20 on IC2801 controls Q419. Mark macafly13 days ago pg e-3 of the service manual says to check pins 1-5 for 5 v on cp2804. I've searched high and low and cannot find cp2804. at cp2802 pins 1-4 show 1.55v and pin 5, 0.00v. Another note, This is the later "A" unit, and I have both service manuals. The "A" manual schematic shows 12v for pins 1-4. I don't understand the circuits, but it seems Q419 controls Q413 and J20 on IC2801 controls Q419. Thanks, Mark I've posted these comments, but have not received any futher assistance. I presume either the digital PCB or power board will solve the problem, but don't know which to try or if their is a little more testing that can be done to solve the problem.
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: By macafly on Mar 05,
I believe the Transistor Q413 is on the T-con board? The one with the LVDS connector going into the display?
Posted on Mar 20, 2011
How do I Fix my tv? My TV plays for awhile and then the screen turns white. Sound is good even when screen is white.
sounds like maybe something is begining to go. I usually recommend that it is reset to factory default through the menus available from a remote control. If, after resetting, the fault persists it must be something to do with the electronic hardware and the fault shoud be diadnosed by a qualified technician.
Jun 02, 2015 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How to troubleshoot lcd tv
If you are using the ANTENNA input mode of the TV and should be receiving a local station on a properly chosen channel then something is wrong with the RF or IF section inside the TV. If you can connect an external video source to the TV see if that works while selecting the proper input mode.
Jul 01, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp LC-26DV24U has Black screen only
The Video/ luminance. or the power voltage supply line is not
working. needs repair.
Nov 01, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
My sharp LC-26DV24U is displaying a white screen only.
I have the same model Sharp TV with the same symptoms. The TV would sometimes work perfectly, then go to white screen (audio OK) and sometimes back to working perfectly again.
I saw Posts saying to check F404 and Q413 - My fuse F404 was not blown, and replacing the Q413 transistor did not fix it.
On Q413 I had about 12.4 VDC on the Emitter, 12.3 VDC on the Base and about 1.5 VDC on the Collector. My service manual called for 11.6 VDC on the Base lead. As a Test, I used a 150 Ohm resistor from Q413 Base to metal chassis ground, and that made the TV work OK.
I replaced the Q419 NPN silicon driver transistor, and now the TV has been restored to 100% proper operation.
I hope that helps someone else down the line.
Mar 27, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
We have a 42" sharp lcd tv we have satellite with
Hi to get the full potential of your Flat Panel, you need to subscribe to a digital HD feed. most likely they will give you a digital box for HD.
Mar 27, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
LC-26DV24U displaying a white screen.
good day the defect is in the main board ,or loose connection in the main board
Jun 20, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Logo
242 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
